i need bios for DELL Latitude 3189
  • rehan
    replied
    DELL 3189
    BOARD NUMBER=LA-E371P
    DONT KNOW ST NUMBER
    STUCK ON DELL LOGO
    ANY GENIUOS CAN HELP
    replied
    Originally posted by Ocajunior
    It says the data size is larger than chip size. Help please...
    I suspect you are trying to flash to the wrong chip. What part number is etched on top. You should always make a backup before trying to flash any other bios.
  • Ocajunior
    replied
    Originally posted by SMDFlea
    Re: i need bios for DELL Latitude 3189
    try this one.
  • BlessedMiracle
    replied
    Hello please fix this bios. it do power on fully, bliking amber lights and white
    TAG: S/N 387F3H2
    here's the dump bin attached
  • pepa13
    replied
    Originally posted by SAF1
    My DELL Latitude 3189 only boot to bios and not windows despite seeing the SSD.
    It gives me an alert (TPM device is not detected), i enable secure boot but same problem.
    i needs help
    I have a similar problem. TPM error. BIOS reflashing did not help, tried several options. Try to enter Windows through the boot menu, pressing F12 during boot and selecting the Windows Boot Manager item. My laptop boots into Windows this way, it works fine, but until the first reboot, then you need to enter the F12 boot menu again.
  • Ali_Khan
    replied
    i needs help
    For booting issue check boot options in bios settings, for tpm alert either upgrade the bios version or downgrade it, if still same issue then dump your bios and upload file here for repair
  • SAF1
    replied
    i needs help
  • munir100
    replied
    DELL Latiude 3189 r ST- GYXZNQ CAV00/CAV10 LA-E371P REV 3 (A02) Problem is no dispaly here is bios file can any fix thanks
  • pepa13
    replied
    Originally posted by danito
    put bios recovery here
    Sorry, I didn’t immediately understand what needed to be done. Lack of knowledge + lack of knowledge of the language, I thought that I needed a backup of the factory BIOS. Here is the BIOS Recovery file copied from the EFI partition. Service Tag 7KPP1N2 - factory, from the laptop cover, registered the first time it was turned on after the firmware.
  • pepa13
    replied
    I received the laptop with a non-native BIOS and without an SSD, so I don't have bios recovery. Inside the SPI Flash the firmware is now Lat_3180_3189_1.17.0 TXE_CLEAN.BIN
    There is a backup of the firmware that was there before.​
  • danito
    replied
    Originally posted by pepa13
    Hello. I need your help. Laptop DELL Latitude 3189, MB CAV00/CAV10 LA-E371P Rev:3.0(A02)
    Express Service Code - 16489968798, Service Tag on the 7KPP1N2 case, there was a different Service Tag in the firmware, the BIOS chip is soldered, that is, the BIOS inside the SPI Flash is not native.
    On loading it says - "Alert! TPM could not be initialized"
    It was sold to me as a working one. I tried all the simple steps. Pulling out the cord, downgrading and upgrading the BIOS version, replacing the battery... I flashed the BIOS from this topic - Lat_3180_3189_1.17.0 TXE_CLEAN.BIN No changes.
    You need a dump BIOS, which may be suitable in this case, or some useful advice.​
  • pepa13
    replied
  • munir100
    replied
    Originally posted by Blaze Tech
    TRY
    thanks for reply but still tpm error
  • Blaze Tech
    replied
    Originally posted by munir100
    THANKS for reply not work
    TRY
  • munir100
    replied
    Originally posted by piszpunta
    try
  • piszpunta
    replied
    I have dell 3189 tpm error can any one fixs thanks st GYXZNQ2 Hera is bios file LA-E371P REV 3.0 (A02)
    try
  • munir100
    replied
  • m.hamzashafiq7810
    replied
    Originally posted by m.hamzashafiq7810
    CAV00/CAV10 LA-E371P REV 2.0 SR2Z5 PENTIUM N4200
    TPM DEVICE IS NOT DETECTED & WINDOWS NOT BOOTING UP
    LAPTOP TURN OFF AFTER THIS MESSAGE
    IN BIOS TPM OPTION ALSO NOT AVAILABLE
    PLZ SOLVE IT PLZ PLZ
    I am sorry
    Service tag 2TG98H2
    commented on 's reply
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
  • m.hamzashafiq7810
    replied
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
  • jhanra
    by jhanra
    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
    11-02-2024, 04:19 AM
    DELL Latitude 3189 Hybrid (2-in-1) 3000 Specification for Upgrade or Repair
    This specification for the DELL Latitude 3189 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3189 boardview and 3189 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
    09-06-2024, 05:40 AM
  • YOUCEF4787
    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
    by YOUCEF4787
    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
    Initial Problem:
    The laptop was completely dead, no signs of life, no power LED.
    Action Taken:
    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
    Current Situation & The Main Issue:
    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
    09-21-2025, 12:19 PM
