i need bios for DELL Latitude 3189
    Re: i need bios for DELL Latitude 3189
    thanks
      i have 3189 every time start laptop time date error plz fix my bios
      servive tag=9G9LNN2
        CAV00/CAV10 LA-E371P REV 2.0 SR2Z5 PENTIUM N4200
        TPM DEVICE IS NOT DETECTED & WINDOWS NOT BOOTING UP
        LAPTOP TURN OFF AFTER THIS MESSAGE
        IN BIOS TPM OPTION ALSO NOT AVAILABLE
        PLZ SOLVE IT PLZ PLZ
        I am sorry
        Service tag 2TG98H2
          I have dell 3189 tpm error can any one fixs thanks st GYXZNQ2 Hera is bios file LA-E371P REV 3.0 (A02)
            try
              Originally posted by piszpunta View Post
              try
              THANKS for reply not work
                TRY
                  Originally posted by Blaze Tech View Post
                  TRY
                  thanks for reply but still tpm error
                    Hello. I need your help. Laptop DELL Latitude 3189, MB CAV00/CAV10 LA-E371P Rev:3.0(A02)
                    Express Service Code - 16489968798, Service Tag on the 7KPP1N2 case, there was a different Service Tag in the firmware, the BIOS chip is soldered, that is, the BIOS inside the SPI Flash is not native.
                    On loading it says - "Alert! TPM could not be initialized"
                    It was sold to me as a working one. I tried all the simple steps. Pulling out the cord, downgrading and upgrading the BIOS version, replacing the battery... I flashed the BIOS from this topic - Lat_3180_3189_1.17.0 TXE_CLEAN.BIN No changes.
                    You need a dump BIOS, which may be suitable in this case, or some useful advice.
                      put bios recovery here
                        I received the laptop with a non-native BIOS and without an SSD, so I don't have bios recovery. Inside the SPI Flash the firmware is now Lat_3180_3189_1.17.0 TXE_CLEAN.BIN
                        There is a backup of the firmware that was there before.
                          Sorry, I didn't immediately understand what needed to be done. Lack of knowledge + lack of knowledge of the language, I thought that I needed a backup of the factory BIOS. Here is the BIOS Recovery file copied from the EFI partition. Service Tag 7KPP1N2 - factory, from the laptop cover, registered the first time it was turned on after the firmware.
                            DELL Latiude 3189 r ST- GYXZNQ CAV00/CAV10 LA-E371P REV 3 (A02) Problem is no dispaly here is bios file can any fix thanks
                              My DELL Latitude 3189 only boot to bios and not windows despite seeing the SSD.
                              It gives me an alert (TPM device is not detected), i enable secure boot but same problem.
                              i needs help
                                i needs help
                                For booting issue check boot options in bios settings, for tpm alert either upgrade the bios version or downgrade it, if still same issue then dump your bios and upload file here for repair
                                  i needs help
                                  I have a similar problem. TPM error. BIOS reflashing did not help, tried several options. Try to enter Windows through the boot menu, pressing F12 during boot and selecting the Windows Boot Manager item. My laptop boots into Windows this way, it works fine, but until the first reboot, then you need to enter the F12 boot menu again.
                                    Hello please fix this bios. it do power on fully, bliking amber lights and white
                                    TAG: S/N 387F3H2
                                    here's the dump bin attached
                                      try this one.
                                      It says the data size is larger than chip size. Help please...
                                        I suspect you are trying to flash to the wrong chip. What part number is etched on top. You should always make a backup before trying to flash any other bios.
