On Board Ram Disable via Bios Editing
  • pcwhiz24
    • Apr 2025
    • 17
    Originally posted by f@brice
    you have to look for schematic, and follow the way on this vidéo :
    https://www.youtube.com/watch?v=Pzkot_awSZk
    Is there any other BIOS hacks I can use with my CH341A? I don't have the soldering skills for parts that small yet.
    • f@brice
      • Nov 2019
      • 76
      • France
      #442
      i don't know other method.
      • pcwhiz24
        • Apr 2025
        • 17
        I just don't know why the two modified BIOS aren't working. I think it's disabling both the onboard RAM and the only DIMM slot too.
        • pcwhiz24
          • Apr 2025
          • 17
          Anyone? I really want to get this thing working. No one else has any other modified BIOS files for this model I can try?
          • Faran Haider
            • Mar 2025
            • pakistan
            #445
            how to disable onboard ddr5 ram ga402rk ddr5x16 any one have solution
          • peste
            • 13209
            • ROMANIA
            #446
            post S/N, full name and model, motherboard model, etc.
            post the original contents of the bios chip..
            • Faran Haider
              • Mar 2025
              • pakistan
              #447
              S/N n4nrkdo20514157 MB part no. ga402rk ddr5x16 DDR5 DISABLE VIA BIOS ANY HAVE SOLUTION
              • f@brice
                • Nov 2019
                • 76
                • France
                #448
                @Faran Haider​
                Disable DDR5 is pretty new, so no garanty.
                Try this and report please.
                • Wicu
                  • May 2025
                  • Polska
                  #449
                  clear
                  188 / 5 000 Wyniki tłumaczenia
                  Tłumaczenie
                  Hi, please disable the built-in RAM, because the memory test does not pass and I have a blue screen, I do not know how to change it myself, maybe someone is experienced in this? below is the data and bios​
                  FX516PC-HN115W
                  Numer seryjny: N6NRKD008320220
                  R 7.0
                  • f@brice
                    • Nov 2019
                    • 76
                    • France
                    #450
                    Originally posted by Wicu
                    clear
                    Tłumaczenie
                    FX516PC-HN115W
                    R 7.0
                    Try and report please
                    • das96
                      • Aug 2024
                      • 14
                      • sri lanka
                      #451
                      ASUS ROG - GL502VT
                      NEED DESABLE ONBOARD MEMORY
                      THANKS IN ADVANCE
                      SN: GCN0CV14C528518
                      asus 502vt old.rar
                      • f@brice
                        • Nov 2019
                        • 76
                        • France
                        #452
                        found only one ref
                        • das96
                          • Aug 2024
                          • 14
                          • sri lanka
                          #453
                          found only one ref
                          ITS WORKING
                          THANK YOU VERY MUCH
                          • Wicu
                            • May 2025
                            • Polska
                            #454
                            unfortunately the laptop after uploading has a black screen, the keyboard lights up and that's it
                            • f@brice
                              • Nov 2019
                              • 76
                              • France
                              #455
                              you have to play with dimm_sel resistors
                              • Wicu
                                • May 2025
                                • Polska
                                #456
                                and you want to tell me if it's enough to just desolder them or move them somewhere else? And if I desolder all the memory chips, it won't see them in the bios either?
                                • f@brice
                                  • Nov 2019
                                  • 76
                                  • France
                                  #457
                                  if the motherboard allows it, by changing resistors position, it should work
                                  • dota1990
                                    • May 2017
                                    • 19
                                    • Philippines
                                    #458
                                    hi can you please disable my onboard ram in bios?
                                    i want to disable my onboard ram because it is failing,
                                    serial number: pf2c997f
                                  • danito
                                    • Jun 2016
                                    • 1050
                                    #459
                                    no ram
                                    • dota1990
                                      • May 2017
                                      • 19
                                      • Philippines
                                      #460
                                      Originally posted by danito
                                      no ram
                                      not working anyways thank you
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • DynaxSC
                                        by DynaxSC
                                        11-17-2023, 10:56 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
