neeb bios TP510UQ REV 2.0
  • Sabina
    • May 2022
    • 67
    • philippines
    Hi i need help? need bios for asus TP510UQ , It turns on but no display Thank you Guys
    here is the orig bin file
  • peste
    • 13451
    • ROMANIA
    Re: neeb bios TP510UQ REV 2.0
    bios and EC extracted from the Asus site update.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12280
      ASUS Vivobook Flip 15 TP510UQ
      • Sabina
        • May 2022
        • 67
        • philippines
        thankyou already tried but still no image , maybe the defect is in the mobo i will look into it
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • Newmultifail
          Asus g750jx Bios turns off after 30 minutes
          by Newmultifail
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
          I should mention that the bios update did not help.
          backup i sn...
          I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
          12-19-2024, 03:41 PM
