I need la-h325p bios please
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Re: I need la-h325p bios please
hi! i need my bios fixed,can someone help me ? turns on no display
HP :15-dw1239nia la-h325p rev :1.0
SN :CND1345BD2
HERE IS MY BACK UPAttached FilesComment
here is my back upAttached FilesComment
pls anyone who can fix bios no display
Hp 15s-du0110tu FPW50 LA-H325PAttached FilesComment
BID : 085F5
DMI : 3C7000h -> 3C900Fh
WINDOWS KEY : 3C5000h -> 3C503FhAttached FilesLast edited by SMDFlea; 12-29-2023, 11:46 AM.↵
​https://www.badcaps.net/donateComment
please i have this hp laptop with the board number LA-H325P with password..
the chip is 4mb.. i have try other ways,but password wont remove.
please me to unlock.
S/N CND13355CR
Thank youAttached FilesComment
Hello aijazli, where you able to sort this issue on your hp FPW50 LA H325P REV 1.0 2019-01-18. mine have same 5 caps long flash and 3 short ones. Pls I will needed the bin if yours workedComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Hi friends, please help. Turns on, no caps lock codes but no display. I try some bios but no changes. Bios version 085f5 F63, Serial CND3192ZNH.
I can program EC ENE KB9022Q
Thanks in advanceComment
Post #6 bios is working! Thanks
TIP: If "manufacture programming mode is in unlock mode" appear when power on, use HP tool https://ftp.ext.hp.com/pub/caps-soft...it/HP_BCU.htmlComment
Hello all
i recive this hp laptop with caps lock 5 slow and 3 fast blink error which indcate bios error
the motherboard numper is FPW50 LA-H325P1 REV 1.0
sn CND131133V
the laptop seems to be bios programed before so i read the bios chip and attached the file
but i think i have to modify this file or it culd be the wrong file programed by some one else
so is there any way that i can find the right bios file because i try some bin files with the same result
i read that i need to modify DMI and some another things in order to be able flash the bios
thank you all in advanceAttached FilesComment
read..https://www.badcaps.net/forum/troubl...before-posting
Post the S/N, post the corrupted bios, the full name and model, etc...
FPW50 LA-H325P REV: 3.0 2021-10-21
HP Notebook - 15-dw1208nia
SN:CND2120XGT
File Size: 4MBComment
Thread merged. The bios should not be 4MB ,choose the chip manually,don`t use autodetect. What is the chip part number,which programmer are you using and the software version .Comment
If you can`t answer all the questions then i can`t help. As i said the the bios should not be 4MB, so you`ve either got the wrong 4MB bios chip on the board or the programmer has wrongly detected the chip. Don`t use ALL CAPS in your reply please !Comment
Thread merged.Post your backup and the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
​Comment
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by al3m0diUpdate bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
The BIOS version is EFCN58WW.
When I turn on the device, it displays the message:
"The Connected AC adapter has a lower wattage than the recommended AC adapter..."
The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
I've tried
Channel: BIOS Requests ONLY!
07-29-2024, 10:32 AM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by ShadowtuySo I'm new here and have successfully unlocked a bios using "RCUnlocker" but after that I'm curious on recovery of a bricked bios from a bad flash/update in a case of NO BACKUP.
The part I'm stuck on is my HP backup are a 32,768KB and 16,384KB image compared to a fresh bios from HP at 23,690KB. How would I use the fresh image to repair a flash chip? The guide I'm following just takes the image and flashes it over but clearly there is more to it.
Just looking to expand my knowledge of this since the password removal worked great. Sorry if I missed this being...09-05-2023, 11:24 AM -
by 0xxHi folks,
My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
I assumed that Windows Update was interrupted due to closing... - Loading...
