Please help unlock 845 g8
  • hamazi
    • Feb 2017
    • 5
    • laghouat
    #61
    Originally posted by rex98
    after reseting bios to defaults just flash the original bios and the password will be cleared
    Thank you Boss !!! Everything working like a charm.
    • Muhammad Faizan
      • Mar 2022
      • 32
      • 000
      #62
      hi i have 845 g8
      in end point security error kindly fix my bios
      Serial Number : 5CG1490GH4
      • m.sabry2110
        • Oct 2017
        • 129
        • egypt
        #63
        Originally posted by Muhammad Faizan
        hi i have 845 g8
        try
        after flash bios
        reset default
        and re-flash original bios
        enjoy​
        • tpchs
          • Mar 2015
          • 3
          • mexico
          #64
          Intente desbloquear el bios , pero no puede y ahora no me enciende el equipo podria alguien ayudarme a sacar el main y ec del backup para intentar reprogramar nuevamente agrezco infinitamente
          Mod 845-g8
          sn/ 5CG149410C
          I tried to unlock the bios, but it can't and now the computer won't turn on. Could someone help me remove the main and ec from the backup to try to reprogram again, I thank you infinitely
          Mod 845-g8
          sn/ 5CG149410C​
          • tpchs
            • Mar 2015
            • 3
            • mexico
            #65
            Mod 845-g8
            sn/ 5CG149410C
            Mod 845-g8
            sn/ 5CG149410C
            Alguien podria ayudarme?
            Somebody could help me?
            • peste
              peste commented
              Editing a comment
              Hey!!! ...please post in English, what you didn't understand....
          • hoaca388
            Badcaps
            • Jan 2022
            • 12086
            #66
            HP EliteBook 845 G8 Notebook PC (545Y2EC)
            • makisdal
              • Jul 2015
              • 20
              • GREECE
              #67
              Could you remove my bios pass?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12086
                #68
                Serial number ? This is rules of forums.
                • makisdal
                  • Jul 2015
                  • 20
                  • GREECE
                  #69
                  HP EliteBook 845 G8
                  ProdID 1W3K6AV
                  SN# 5CG20742JJ
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12086
                    #70
                    HP EliteBook 845 G8
                    ProdID 1W3K6AV
                    SN# 5CG20742JJ
                    CT Number_6LGWR0JVTFY40I
                    Serial_5CG20742JJ
                    Product_1W3K6AV
                    Feature byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPgSguhKjhk8mEn7nWngpD.gG
                    Build Id_21WWLCCT601#SABB#DABB
                    • makisdal
                      • Jul 2015
                      • 20
                      • GREECE
                      #71
                      Thank you so much hoaca388
                      It works fine
                      • hyditech
                        • 272
                        • nigeria
                        #72
                        help me to unlock hp 845 g8
                        S/N 5CG3072MS7
                        THANKS
                        • panzli
                          • Aug 2024
                          • 3
                          I also have a Elitebook 845 G8 AMD and a few questions about dumping the bios/ec chip.
                          Is the EC chip on the backside (keyboard side)? I only could recognize a Winbond 25Q256JVEN behind the cover.
                          I tried to dump the IC data from the chip, but the Neo Programmer 2.2.0.01 only have a 25Q256JV chip selectable is that bad?
                          And my third problem is, that the IC not responds (I think there is not a contact between the flashing clamp of the CH341a). Is there any cheap programmar or clamp or should I try to desolder the chip?
                          Thank You
                          • panzli
                            • Aug 2024
                            • 3
                            According to an ebay auction, this is the backside of the motherboard:
                            But I could detect any Bios/EC Chip... Does anybody where the chip is located?
                            • meta99
                              • Sep 2021
                              • 27
                              • Vietnam
                              #75
                              Hello
                              Please help. My HP Elitebook 845 G8 has error "HP Endpoint Security Controller Problem".
                              Model: HP Elitebook 845 G8
                              Serial: 5CG20266ZJ
                              BIOS file attached. Thanks a lot
                              HP_845_G8_BIOS.rar
                              • tktrom
                                • Jul 2022
                                • 79
                                • Bolivia
                                #76
                                Good afternoon, could you help me activate absolute persistence module permanently disable.
                                thank you
                                Hp 845 G8
                                SN 5CG2473KSH
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12086
                                  #77
                                  thank you
                                  Hp 845 G8
                                  SN 5CG2473KSH
                                  Try
                                  • tktrom
                                    • Jul 2022
                                    • 79
                                    • Bolivia
                                    #78
                                    Originally posted by hoaca388
                                    Try
                                    Thank you very much perfect work
                                    • futadmytro
                                      • Aug 2020
                                      • 62
                                      • Сполучені Штати
                                      #79
                                      please help to unlock hp 845 g8
                                      ​sn 2TK2160KLL
                                      U366
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12086
                                        #80
                                        ​sn 2TK2160KLL
                                        U366
                                        Unlocked
                                        • Syseng
                                          Lenovo P14s Gen 5 SVP unlock
                                          by Syseng
                                          This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                          The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                          06-22-2025, 07:44 AM
                                        • remizbushka
                                          Dell inspirion 5775 bios "Unlock Setup fail"
                                          by remizbushka
                                          Hi sirs. please help
                                          Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                          After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                          What I did:
                                          I read the bios dump.
                                          Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                          03-24-2025, 09:07 AM
                                        • salim5566
                                          loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                          by salim5566
                                          Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                          06-26-2025, 03:25 PM
                                        • Syavko1
                                          Unlock Bios HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          by Syavko1
                                          Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
                                          I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? ​
                                          01-22-2025, 02:04 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
