Please help unlock 845 g8
  • futadmytro
    • Aug 2020
    • 62
    • Сполучені Штати
    #81
    Originally posted by hoaca388
    Unlocked
    Works!!! Thank you!!!
    • amine23000
      • Nov 2022
      • 6
      • Algérie
      #82
      HP 845 NO DISPLAY
        SMDFlea commented
        Editing a comment
        Read the rules, post the required laptop serial number
    • amine23000
      • Nov 2022
      • 6
      • Algérie
      #83
      can you help me i need the good dunp
      • peste
        peste commented
        Editing a comment
        Did you read what is written above??? respect the rules and post S/N and if someone has time they will help you..
    • amine23000
      • Nov 2022
      • 6
      • Algérie
      #84
      hp 845 g8 not display
      s/n 5CG2375N7M
      • shiyab
        • Sep 2023
        • 1592
        • india
        #85
        s/n 5CG2375N7M
        post both file this not main file
        • duong.160694@gmail.com
          • Nov 2017
          • 27
          • viennam
          #86
          HP 845g8 pass bios ( chip AMD 6050a3234201-mb-a01)
          SN: 5CG20913PB
          ProdID: 4L6P1UC#ABA
          FIX!!PLS!! TKS
          • minhdigital
            • Nov 2022
            • 764
            • Vietnam
            #87
            SN: 5CG20913PB
            ProdID: 4L6P1UC#ABA
            FIX!!PLS!! TKS
            Send to you
              • Nov 2017
              • 27
              • viennam
              #88
              Originally posted by minhdigital
              Send to you
              tks! DONE<3
              • amine23000
                • Nov 2022
                • 6
                • Algérie
                #89
                s/n 5CG2375N7M
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12280
                  #90
                  s/n 5CG2375N7M
                  Post main bios dump.
                  • amine23000
                    • Nov 2022
                    • 6
                    • Algérie
                    #91
                    i post it you can see before
                    • shiyab
                      • Sep 2023
                      • 1592
                      • india
                      #92
                      post both file
                      • rhino3
                        • Feb 2025
                        • 5
                        I did dump of my EC chip and removed Nvram region to remove password. Worked fine, except now I get HP endpoint error every boot.
                        I have original dump of EC, but I never made dump of main bios yet (I can if needed), I also updated the BIOS to newer version since then. Does this mean I just have to deal with it now? Or can still be fixed?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12280
                          #94
                          Post main bios file.
                          • rhino3
                            • Feb 2025
                            • 5
                            Here it is. Any other info needed?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12280
                              #96
                              HP endpoint error
                              • rhino3
                                • Feb 2025
                                • 5
                                HP endpoint error
                                I flashed new BIOS, and it put it into manufacturing mode. I then reset BIOS to factory settings and then reset security settings. what now?
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12280
                                  #98
                                  Nevermind, I looked it up and put in all my DMI information and it worked! Thank you very much sir, I really appreciate it! 👍👍👍
                                  I know this is the thread for the 845 G8, but I also have the 845 G7 with the same issue, would you be able to provide the updated BIOS file for that one as well? Here is Main BIOS dump. Again thank you very much!!
                                  Post bios on the correct topic.
                                  • ByteNest
                                    • Sep 2025
                                    • India
                                    #99
                                    HI,
                                    Need clean BIOS (main & EC) for HP EliteBook 845 G8
                                    S/N: 5CG2090VM5
                                    Motherboard P/N: 6050A3234201
                                    Current issue: Old BIOS corrupted, laptop shows no display after flash. Need correct dumps to revive the board.
                                    • peste
                                      • 13451
                                      • ROMANIA
                                      #100
                                      Originally posted by ByteNest
                                      HI,
                                      S/N: 5CG2090VM5
                                      post the contents of the bios chip even if it is corrupted..
                                      • qsenc
                                        ThinkBook 14/15 G2 ARE bios unlock
                                        by qsenc
                                        Hi guys,
                                        i have looked everywhere for a way to unlock this bios but seems only G2 ITL has a way to be unlocked ( witch i thought is the same) , but not this model. Also i have looked for a hardware way for unlock.
                                        Did anyone had success to unlock this model?
                                        Thank you
                                        ThinkBook 15 G2 ARE Laptop - Type 20VG
                                        Serial Number MP1X30S7
                                        Machine Type Model 20VG0008UK...
                                        09-17-2025, 11:59 PM
                                      • Syseng
                                        Lenovo P14s Gen 5 SVP unlock
                                        by Syseng
                                        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                                        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                                        06-22-2025, 07:44 AM
                                      • remizbushka
                                        Dell inspirion 5775 bios "Unlock Setup fail"
                                        by remizbushka
                                        Hi sirs. please help
                                        Dell Inspiron 5775 bios locked "Unlock Setup fail"
                                        After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
                                        What I did:
                                        I read the bios dump.
                                        Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....
                                        03-24-2025, 09:07 AM
                                      • masterbateson
                                        hp 8570p and also a hp8470p bios locked cant get rc unlocker to load/work
                                        by masterbateson
                                        as above really in title.
                                        hp 8570p and also a hp8470p bios locked cant get rc unlocker to load/work error messages same with hp unlocker.
                                        cant seem to find hpunlocker now, ive tried downloading so many things and trying them, wasted 8hrs already.
                                        any help would be great, thanks in advance....
                                        10-03-2025, 04:31 AM
                                      • salim5566
                                        loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                        by salim5566
                                        Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                        06-26-2025, 03:25 PM
