Asus x512d
  • String2016
    replied
    Re: Asus x512d
    Thanks already done that but there is the problem cannot write the chip it says write false, maybe this kbc is faulty
    replied
    Re: Asus x512d
    Originally posted by String2016
    thanks but i have a prolem programming ec using svod 3 ITE not detected
    @mcplslg123 to the rescue https://www.badcaps.net/forum/showth...light=svod+ITE
  • String2016
    replied
    Re: Asus x512d
  • peste
    replied
    Re: Asus x512d
    does anyone have a EC on this i will try flash ec
    Bios and EC extracted from the Asus site update
  • String2016
    replied
    Re: Asus x512d
  • String2016
    replied
    Re: Asus x512d
    amp draw is 0.006
  • String2016
    replied
    Re: Asus x512d
    Already tried removing and plugging back in still no light when charger plugged in
    replied
    Re: Asus x512d
    Tried it still there is no light 1.8v on pin 3 7 8 on the bios chip is present and there is 3.3v on keyboard switch , history of this laptop battery drain then suddenly not working,I have attached original file ec is IT8225E
    battery drain is unlikely to be a bios problem.If there is no cmos battery then the main battery is used as cmos for the RTC .
  • String2016
    replied
    Re: Asus x512d
    replied
    Re: Asus x512d
    @smdflea here is the info sticker please thanks for the response
    You didnt post your bios backup.If you want to add your DMI use Asus Block Transmit tool (WBT.exe windows version) https://www.badcaps.net/forum/showpo...43&postcount=5 ,or you can add it with a hex editor from your backup. If there is a win key its best to add the dmi from your backup .
  • hoaca388
    replied
    Re: Asus x512d
    ASUS Vivobook 15 X512DK
  • String2016
    replied
    Re: Asus x512d
    replied
    Re: Asus x512d
    I need a workng bios on this model Asus x512d , laptop suddendly not working check all voltages present, and theres is 1.8v on pin 3 7 8 of the bios chip anyone have a working dump please
    That QR code is the heatsink part number. Is there a long white barcode sticker on the other side of the board near the soldered ram.
    If there are no stickers post the silkscreened part number, such as X512DK Rev
  • mon2
    replied
    Re: Asus x512d
    1v8 for a flash bios chip is normal these days. It is very possible that your flash device is truly designed to operate @ 1v8.
    What are the full markings on the flash device ? With this detail -> search for the datasheet and review the voltage range for the Vcc parameter = power rail. Respectively, the I/O pins will also toggle at the same max voltage value.
  • String2016
    started a topic Asus x512d
    Asus x512d
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • lrouw84
    by lrouw84
    Hi there,
    01-28-2023, 01:31 PM
