Unlock Lenovo 500e bios
good afternoon, can you please help. I have the developer mode blocked and it is connected to the corporate mode almost and I cannot bypass itAttached FilesComment
Every donation made will go towards server fees and maintenance costs.Comment
Need Bios
Lenovo 500e Yoga Chormebook gen 4
SN : PF4TEEVB
kc4la/kc25a/kc2ca nm-e931 rev.1.0 bin
No backup fileComment
I have an 500e (1st gen) and having issues reading the bios chip. As far as I can see, its a Windbond 25Q128FW. I can't find that exact model in my programmer software CH341a Programmer 1.13. When looking up the SoC, it seems it's on 1.8V, so I assume that's what I should set my programmer to? In the software, I pick the closest SoC I can find, which is W25Q128BV. When I read it, it only returns all FF or 00. Any pointers to how I should proceed? Get another software? if so, which one? Change voltage?Comment
https://www.badcaps.net/forum/showpo...6&postcount=10
https://www.badcaps.net/forum/showpo...postcount=7Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
read the rules..https://www.badcaps.net/forum/troubl...before-posting
post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
serial_number: PF2WF0GY
model:Lenovo 500e Chromebook 2nd GenComment
Hello. Can anyone restore this BIOS backup file? I have no image after flashing the BIOS, developer mode is locked and it is connected to enterprise mode, I can't bypass it.
Serial Number: P208PD3P
Model: Lenovo 500e Chromebook 2nd Gen (81MC)Attached FilesLast edited by ElironService Work; 07-19-2025, 05:12 AM.Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM - Loading...
