ASUS ZenBook Pro UX550V Bios bin
  • mydayparade
    • Jan 2021
    • 27
    • philippines
    please help. need bios bin badly
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: ASUS ZenBook Pro UX550V Bios bin
    Upload your original corrupt bios file.
    • mydayparade
      • Jan 2021
      • 27
      • philippines
      it cannot be read it always failed
        • 22293
        It shouldn`t be a Cypress chip.Choose the chip manually by the part number on top.If it is a cypress chip then youve found the wrong one.
        Look for the bios like the one in the attached picture,its on the right side, it could be a macronix chip marked MXIC
        • mydayparade
          • Jan 2021
          • 27
          • philippines
          i did manually its a winbond W25Q80V@SOIC8,
          • hoaca388
            Badcaps
            • Jan 2022
            • 12441
            Wrong chip.
              • 22293
              Wrong one.See post #4 i edited it and added a picture
              • mydayparade
                • Jan 2021
                • 27
                • philippines
                i thnk the bios chip is broken. thats whty it cannot be read. can i just replace it with other same brand winbond then write the bios bin file. is someone share it.
                  • 22293
                  Wrong,see post #7 .The W25Q80 is 8 megabits,not megabyes.It is 1MB megabyte, an 8MB bios will not fit onto it
                  W25Q80: 8M-bit / 1M -byte (1,048,576) datasheet - https://pdf1.alldatasheet.com/datash...ND/W25Q80.html
                  • mydayparade
                    • Jan 2021
                    • 27
                    • philippines
                    u mean that chip is the bios chip of this laptop?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12441
                      If you are using a chip clip, remove all batteries from the main board, including the CMOS battery.
                      • mydayparade
                        • Jan 2021
                        • 27
                        • philippines
                        finally i found it this is my backup bios laptop no power
                          • 22293
                          The chip is not SOIC16 ,it has 8 legs,so choose @SOIC8 .The programmer probably read it ok but check it yourself next time and choose the chip manually by the part number on top of the chip and the type of package, SOIC8,SOIC16,WSON8 etc
                          • mydayparade
                            • Jan 2021
                            • 27
                            • philippines
                            understand and noted boss. thank you for your tip
                            • mydayparade
                              • Jan 2021
                              • 27
                              • philippines
                              i dont use that clip thingy
                              i soldered out the chip using hot air.
                                • 22293
                                If there is a long white barcode sticker under the SSD drive or on the ram slot,or a square white QR code on the motherboard post a picture of it
                                • mydayparade
                                  • Jan 2021
                                  • 27
                                  • philippines
                                  i saw this two
                                  • mydayparade
                                    • Jan 2021
                                    • 27
                                    • philippines
                                    other 2 sticker on the other side
                                    • DanielDacko
                                      • Mar 2015
                                      • 329
                                      • Macedonia
                                      Try this file.
                                      I don't provide help for people using CH341A and a clip.
                                        • 22293
                                        i saw this two
                                        The sticker on the heatsink is the part number for the heatsink. The sticker or QR code will be on the motherboard !
                                        "If there is a long white barcode sticker under the SSD drive or on the ram slot,or a square white QR code on the motherboard post a picture of it "
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
