Acer v3-112p C5YZ bios
  • huzo
    • Sep 2014
    • 178
    • CROATIA
    Hello all, i have above mentioned laptop, and the original bios that is on the 25LQ64CSIG turns the blue lamp for a second or two, and then goes out, and goes around in loop, but i've downloaded other bios by board type, and then i have blue light on, it detects charger when i disconnect/connect , it beeps, but there is no picture on the screen...
    the board is : DA0ZHKMB6C0 Rev:C
    the model is : V11 touch, V3-112P-C5YZ
    can someone fix my bios?
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria πŸ‡§πŸ‡¬
    Re: Acer v3-112p C5YZ bios
    Become a Badcaps supporter
    Thanks to all supporters.​
    • huzo
      • Sep 2014
      • 178
      • CROATIA
      thanks Vasko,i flashed it,but no image still....
      • DanielDacko
        • Mar 2015
        • 325
        • Macedonia
        Extracted from official update, try and report back.
        I don't provide help for people using CH341A and a clip.
        • huzo
          • Sep 2014
          • 178
          • CROATIA
          this is 4mb,mine is 8mb
          • satishkumar
            • Sep 2015
            • 164
            • India
            hello all, i have above mentioned laptop, and the original bios that is on the 25lq64csig turns the blue lamp for a second or two, and then goes out, and goes around in loop, but i've downloaded other bios by board type, and then i have blue light on, it detects charger when i disconnect/connect , it beeps, but there is no picture on the screen...
            The board is : Da0zhkmb6c0 rev:c
            the model is : V11 touch, v3-112p-c5yz
            • huzo
              • Sep 2014
              • 178
              • CROATIA
              @satishkumar, thank you, but no image again...
              i have tried like a dozen of files, all don't have image...but my original goes to the blue light loop...this board only has intel processor,no additional graphic chip...maybe that is the key to solving?
              • satishkumar
                • Sep 2015
                • 164
                • India
                its motherboard problem not bios issue
                • huzo
                  • Sep 2014
                  • 178
                  • CROATIA
                  i am starting to think that too...
                  but why does my original bios go to loop,and all others are turning on?
                  All voltages present, cpu is warm,but no image,no usb communication,there is usb power,but no communication, it won't even search usb when i press fn+esc...
                  what to look on the board? reflow cpu?
                  • huzo
                    • Sep 2014
                    • 178
                    • CROATIA
                    i found the problem! on ram socket there was a piece of dirt/oxide, i've cleaned it, and it works now! thank you all!
                    • EbrahimSiami
                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                      by EbrahimSiami
                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                      **What I have tried so far:**
                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                      07-02-2025, 02:31 PM
                    • Wg188
                      ACER Veriton Z4660G AIO bios help
                      by Wg188
                      I have an Acer veriton Z4660G all in one pc,
                      Model: Z4660G-I5850H1 (VZ4660G_W)
                      Need bios dump and schematic would save my life !
                      to make a long story short I bought this all in one used
                      with a broken lcd, with the objective of making a custom desktop out of it
                      ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                      06-17-2023, 02:20 PM
                    • James194zt
                      Acer Nitro 50-640E Corrupted BIOS Dump
                      by James194zt
                      My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                      All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                      04-28-2025, 03:29 PM
                    • Amohac
                      BIOS LOCKED ACER R753T-C1LK
                      by Amohac
                      Hi, I have an Acer Chromebook R753T
                      with administrator lock. Could something be done in the BIOS. Attached is the β€œBIN” backup.
                      Thank you.
                      Computer:
                      Acer Chromebook R753T-C1LK
                      Mother: DA0ZCAMB8D0 NETWORK: D
                      HSB J / 94V-0 / E89382 / 442 1/ MV-4
                      Bios: WINBOND 25Q128JVPM /2139/ M138/ 42300
                      16 MB
                      Serial NO: NXA8ZAA0031501A1A87600
                      SNID: 15010692076
                      Model NO: N20Q10
                      MFG Date: 2021/12/20....
                      06-30-2025, 06:05 PM
                    • ub6ib969
                      Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
                      by ub6ib969
                      Model Number: PO3-650
                      Part Number: DG.BK4AA.006
                      Serial Number : 33400117730
                      BIOS IC : XM25QH256C
                      I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
                      07-02-2025, 03:51 PM
