Acer v3-112p C5YZ bios
    Hello all, i have above mentioned laptop, and the original bios that is on the 25LQ64CSIG turns the blue lamp for a second or two, and then goes out, and goes around in loop, but i've downloaded other bios by board type, and then i have blue light on, it detects charger when i disconnect/connect , it beeps, but there is no picture on the screen...
    the board is : DA0ZHKMB6C0 Rev:C
    the model is : V11 touch, V3-112P-C5YZ
    can someone fix my bios?
    Re: Acer v3-112p C5YZ bios
    Become a Badcaps supporter
    Thanks to all supporters.​
      thanks Vasko,i flashed it,but no image still....
        Extracted from official update, try and report back.
        I don't provide help for people using CH341A and a clip.
          this is 4mb,mine is 8mb
            hello all, i have above mentioned laptop, and the original bios that is on the 25lq64csig turns the blue lamp for a second or two, and then goes out, and goes around in loop, but i've downloaded other bios by board type, and then i have blue light on, it detects charger when i disconnect/connect , it beeps, but there is no picture on the screen...
            The board is : Da0zhkmb6c0 rev:c
            the model is : V11 touch, v3-112p-c5yz
              @satishkumar, thank you, but no image again...
              i have tried like a dozen of files, all don't have image...but my original goes to the blue light loop...this board only has intel processor,no additional graphic chip...maybe that is the key to solving?
                its motherboard problem not bios issue
                  i am starting to think that too...
                  but why does my original bios go to loop,and all others are turning on?
                  All voltages present, cpu is warm,but no image,no usb communication,there is usb power,but no communication, it won't even search usb when i press fn+esc...
                  what to look on the board? reflow cpu?
                    i found the problem! on ram socket there was a piece of dirt/oxide, i've cleaned it, and it works now! thank you all!
