BIOS for Asus X515EA
  • bushmann
    • Feb 2014
    • 147
    • Slovakia
    Hello .
    Please, I need BIOS for ASUS X515EA.
    So, I test X415EA but not work keyboard.
    If I extract for ITE block from my old BIOS to X415EA all work fine.
    But after update BIOS same problem, becouse ITE chip update every all start up and X415EA have another binary code for ITE .
    If I don't update BIOS all work fine.
    Thanks for your help.
    • 22035
    Re: BIOS for Asus X515EA
    Originally posted by bushmann
    Hello .
    Post a picture of the white/green barcode sticker,or white square QR code on the motherboard. The QR code,if there is one could be under the wifi card,under a sticker or heatsink.
    • bushmann
      • Feb 2014
      • 147
      • Slovakia
      Photos has been added.
        • 22035
        • bushmann
          • Feb 2014
          • 147
          • Slovakia
          System power on normal, but not work advanced menu, Boot menu and any change in BIOS.
          After restore factory BIOS from USB all work fine.
          I am enclosing a fully functional BIOS ver 307.
          Thank you so much.
          • koby058
            • Jan 2017
            • 387
            • israel
            Hi
            Asus x515ja-br3853w powers on only some times. or after a long press on power button
            MODEL: X515JA-BR3853W
            SERIAL: NAN0CX04467743F
            MOTHERBOARD: X415JA R4.2
            can you please help with clean me or any other idea ?
            attached bios
          • koby058
            • Jan 2017
            • 387
            • israel
            Hi
            Sorry and thank you. i have added the requested details. can any on please help with this ?
              SMDFlea commented
              Editing a comment
              Can you find a QR code on the motherboard ,like the 2nd picture at post 1. Not the one on the heatsink, only on the board.
            • Vesko356
              Vesko356 commented
              Editing a comment
              The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on. Next time make sure to do it as it should to avoid unnecessary clarifications and wasting of time please.
          • koby058
            • Jan 2017
            • 387
            • israel
            As i recall, there was no QR code but i will look again
            I have update it, is this what needed?
            • koby058
              • Jan 2017
              • 387
              • israel
              I am sorry for the inconvenience. I think it is now as expected i will do my best for next time posts.
              Also, i have added a picture with QR code on the mother board
              Can any one help ?
              • dhudz1968
                • Feb 2018
                • 3
                • philippines
                please help me unlock my bios
                MODEL X515EA-BQ868T
                BOARD: x415ea REV 6.0
                SN:MAN0CV04449708
                nvme ssd lock.. i cant install os
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12356
                  MODEL X515EA-BQ868T
                  SN:MAN0CV04449708
                  Unlocked.
                  ​https://www.badcaps.net/donate
                  • salawayon
                    • Nov 2012
                    • 578
                    • philippines
                    attached bios file with keyboard issue.
                    infos:
                    X415EA REV 6.1
                    SN: N2NCXV09L61107A
                    the bios file at post #4 is working, but i want to restore the DMI and WINKEY data. thanks
                    • salawayon
                      • Nov 2012
                      • 578
                      • philippines
                      sorry, i thought my attachment went missing. it was just my network. thanks..
                        • 22035
                        Originally posted by salawayon
                        sorry, need to re-attached my backup. it went missing from the original post.
                        thank you...
                        Do you know how to use a hex editor
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12356
                          infos:
                          X415EA REV 6.1
                          SN: N2NCXV09L61107A
                          There is no DMI and Window key in the file you posted.
                          • salawayon
                            • Nov 2012
                            • 578
                            • philippines
                            it's damaged? i checked it also on hex editor and can't find those. any option to restore the DMI and winkey?
                            • salawayon
                              • Nov 2012
                              • 578
                              • philippines
                              yes. but just basic operation only.
                                • 22035
                                Copy the DMI from the bios at post 4 , 660000 - 66FFFF .Is the serial number you posted correct ? .HxD hex editor has a replace function under the Search. You can replace the existing serial number with your own,but it must be the same length
                                • salawayon
                                  • Nov 2012
                                  • 578
                                  • philippines
                                  tried and no SN on bios setup menu. my backups seems corrupted on that area.. it just contain FFFFFFFF.. two backups just the same...
                                  • salawayon
                                    • Nov 2012
                                    • 578
                                    • philippines
                                    using the bios file on post #4 i just replaced the SN with the one on sticker and it restored the original SN. winkey somewhat can't be recovered or restored anymore..
                                    • exerion5000
                                      Bios Needed For Asus X515EA Pcb X415EA R2.0
                                      by exerion5000
                                      Asus X515EA_No Power_GD25B127D@SOIC8.rar
                                      Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
                                      02-17-2025, 01:34 PM
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • Exclikers
                                      ASUS X515EA - X415EA Rev 6.0 Bios Bin
                                      by Exclikers
                                      Hi, Please help me with my laptop, I have this ASUS X515 that has BIOS password. I try to flash with BIOS X415EA Rev 2.0 but the keyboard wont work.
                                      Then I try to flash with X515EA , the keyboard works but SSD wont detect
                                      Is there any correct bios file for my unit? The Model is Asus X515EA on the sticker and X415EA R6.0 printed on the motherboard.. please see the attached image
                                      The attached Bios bin was the original BIOS but has a Password..
                                      Thank you...
                                      06-02-2022, 10:07 AM
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • davidebeatrici
                                      Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                                      by davidebeatrici
                                      I had 3 people contact me in a week because Windows suddenly didn't boot:
                                      As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                                      The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                                      Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                                      06-17-2025, 12:59 PM
