BIOS for Asus X515EA
    Hello .
    Please, I need BIOS for ASUS X515EA.
    So, I test X415EA but not work keyboard.
    If I extract for ITE block from my old BIOS to X415EA all work fine.
    But after update BIOS same problem, becouse ITE chip update every all start up and X415EA have another binary code for ITE .
    If I don't update BIOS all work fine.
    Thanks for your help.
    Re: BIOS for Asus X515EA
    Originally posted by bushmann View Post
    Hello .
    Post a picture of the white/green barcode sticker,or white square QR code on the motherboard. The QR code,if there is one could be under the wifi card,under a sticker or heatsink.
      Photos has been added.
          System power on normal, but not work advanced menu, Boot menu and any change in BIOS.
          After restore factory BIOS from USB all work fine.
          I am enclosing a fully functional BIOS ver 307.
          Thank you so much.
            Hi
            Asus x515ja-br3853w powers on only some times. or after a long press on power button
            MODEL: X515JA-BR3853W
            SERIAL: NAN0CX04467743F
            MOTHERBOARD: X415JA R4.2
            can you please help with clean me or any other idea ?
            attached bios
            Hi
            Sorry and thank you. i have added the requested details. can any on please help with this ?
              SMDFlea commented
              Editing a comment
              Can you find a QR code on the motherboard ,like the 2nd picture at post 1. Not the one on the heatsink, only on the board.
            • Vesko356
              Vesko356 commented
              Editing a comment
              The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on. Next time make sure to do it as it should to avoid unnecessary clarifications and wasting of time please.
            As i recall, there was no QR code but i will look again
            I have update it, is this what needed?
              I am sorry for the inconvenience. I think it is now as expected i will do my best for next time posts.
              Also, i have added a picture with QR code on the mother board
              Can any one help ?
                please help me unlock my bios
                MODEL X515EA-BQ868T
                BOARD: x415ea REV 6.0
                SN:MAN0CV04449708
                nvme ssd lock.. i cant install os
                  MODEL X515EA-BQ868T
                  SN:MAN0CV04449708
                  Unlocked.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    attached bios file with keyboard issue.
                    infos:
                    X415EA REV 6.1
                    SN: N2NCXV09L61107A
                    the bios file at post #4 is working, but i want to restore the DMI and WINKEY data. thanks
                      sorry, i thought my attachment went missing. it was just my network. thanks..
                        Originally posted by salawayon View Post
                        sorry, need to re-attached my backup. it went missing from the original post.
                        thank you...
                        Do you know how to use a hex editor
                          infos:
                          X415EA REV 6.1
                          SN: N2NCXV09L61107A
                          There is no DMI and Window key in the file you posted.
                            it's damaged? i checked it also on hex editor and can't find those. any option to restore the DMI and winkey?
                              yes. but just basic operation only.
                                Copy the DMI from the bios at post 4 , 660000 - 66FFFF .Is the serial number you posted correct ? .HxD hex editor has a replace function under the Search. You can replace the existing serial number with your own,but it must be the same length
                                  tried and no SN on bios setup menu. my backups seems corrupted on that area.. it just contain FFFFFFFF.. two backups just the same...
                                    using the bios file on post #4 i just replaced the SN with the one on sticker and it restored the original SN. winkey somewhat can't be recovered or restored anymore..
