BBS MOD MxP APPLE BLACK BOARD SERIALIZER
+ More Options
Posts
  • ibo
    • Oct 2019
    • 93
    • Turkiye
    #41
    Originally posted by Peterpan1234
    is it possible to remove the iCloud activation lock on an a1708 MacBook with the serializer?
    After change the serialnumerb it should be possible to activate or?
    best regards
    No, it will only work for MDM lock
    if you dump your bios someone will remove your icloud
    • Peterpan1234
      • Apr 2024
      • Czech
      #42
      Okay thanks for your answer.
      When I have everything I will do it.
      But is the activation lock not server relation because of serialnumber?
      • ibo
        • Oct 2019
        • 93
        • Turkiye
        #43
        No
        • Cupskhocup
          • Sep 2024
          • Indonesia
          #44
          Hello sir, can i have the .img format file?
          • zenon_brak
            • Nov 2024
            • US
            #45
            Hi @Maxpower3, was it tested with the Late 2013 "Trash Can" Mac Pro (MacPro6,1)?
            On my machine, it causes a black screen and a couple of restarts. After that, it chimes and returns to the boot screen.
            • nodoze
              • Jan 2025
              Thanks a TON! With all the other methods and images out there, for some reason this is the only one that has worked for me.
              I even rolled back to Mojave!
              I have a Mac Pro 2013 "Trash Can" (MacPro6,1) which I put a spare Apple SSD (256GB) and installed Mojave (because I thought Monterey wasn't allowing me to boot to the other image thumb drives I made).
              • nodoze
                • Jan 2025
                Yes, I just did it on my Mac Pro 2013 "Trash Can (MacPro6,1) but I rolled back to Mojave since the other images weren't working I thought Monterey wasn't letting me boot to those drives.
                Used Disk Utility to restore the .IMG onto a thumbdrive, restarted and held down Option. Booted into the serializer.
                After putting in the serial number (twice, one for verification), it went and checked the computer for 10 minutes and it said that there were no problems. Then I restarted and checked - I now have my serial number back!
                Thanks again Maxpower3.
                • xspider
                  • Nov 2023
                  Originally posted by Maxpower3
                  *********** BLACK BOARD SERIALIZER ***********
                  Blank Board Serializer is mod by MxP !! Enjoy !!!
                  Setting serial number is too easy
                  " Only for all Mac models 2009 to 2017 "
                  This USB tool helps to:
                  Change the Serial Number (SSN) or add a new Serial Number.
                  It supports all type of Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini and Mac Pro (2009 to 2017).
                  * Use RUFUS to create USB key with .img
                  ** The process is as simple as booting the Mac from the USB tool, type a new serial number and confirm.
                  --------------------------- WARNING--------------------------------------
                  Some letters are prohibited from origin program by Apple "AEIOUBSZ". (look pics)
                  I authorized them in this version for test.
                  Don't Use if you don't know
                  This is not a crack of MacUnlock version, just this inspired me and I searched
                  Just need a little usb key
                  Archive Size: 389*Mo /.img Size: 494*Mo
                  Where is the img file? Thanks
                  • nodoze
                    • Jan 2025
                    DL the txt file in the OP’s post. the URL is there.
                    • hades2736
                      • Feb 2025
                      Thank you.
                      • Ba Pham Quang
                        • Oct 2024
                        • VIET NAM
                        #51
                        plz link download?.
                          SMDFlea commented
                          Editing a comment
                          Read post 1 and 2
                      • lord_chen
                        • Apr 2025
                        • 中国
                        #52
                        Hi gents, I tried to run it on Macbook Pro A1278 (Early 2011), and also Macbook Air A1370 (Mid-2011), it worked!
                        But it couldn't work on Macbook Pro A1286 (Mid-2009), neither nor Macbook A1342 (Mid-2010), stuck in a black screen with a cursor, and then automatically restart after a while, can anybody help?
                        • Vmalpica01
                          • Oct 2020
                          • 27
                          • Colombia
                          #53
                          Originally posted by anhbanxoi
                          Re: BBS MOD MxP APPLE BLACK BOARD SERIALIZER
                          Same thing.
                          Muchas gracias, funciono en A1466 EMC 2632
                          English - Thank you very much, it worked on A1466 EMC 2632​
                          • jaberz
                            • Aug 2018
                            How do I get the link? Thanks
                              SMDFlea commented
                              Editing a comment
                              Read post 1 and 2
                          • Carl-Kristjan Lepasaar
                            • Mar 2025
                            • Estonia
                            #55
                            Could anyone PLEASE help me understand step-by-step EXACTLY HOW can I make these folders and files downloaded from here bootable on usb stick via rufus?
                            I honestly have no clue how to do that. Thanks!
                            • gotsqueeze2345
                              • Aug 2025
                              • usa
                              #56
                              btw, u probably need Windows computer to run Rufus.
                              download rufus, download the .dmg that you want to have rufus write to your usb drive, plug in the usb drive, open rufus after installing it, once open select the drive that you want the program to be installed on (your usb drive), select the file that you want written to the usb drive (the program you downlaoded from the address from the file that you downloaded from the OP , the first thead on this topic), u shouldnt need to change any thing else on the program just run it to create the bootable usb drive. restart the computer and hold down option and select the usb drive to boot from, hope it works.
                              • gotsqueeze2345
                                • Aug 2025
                                • usa
                                #57
                                IF that was too confusing, just read the help file on rufus or watch a video on youtube. anyhow always read or watch what u want to know and you will learn.
