BBS MOD MxP APPLE BLACK BOARD SERIALIZER
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1599
    • France
    *********** BLACK BOARD SERIALIZER ***********
    Blank Board Serializer is mod by MxP !! Enjoy !!!
    Setting serial number is too easy
    " Only for all Mac models 2009 to 2017 "
    This USB tool helps to:
    Change the Serial Number (SSN) or add a new Serial Number.
    It supports all type of Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini and Mac Pro (2009 to 2017).
    * Use RUFUS to create USB key with .img
    ** The process is as simple as booting the Mac from the USB tool, type a new serial number and confirm.
    --------------------------- WARNING--------------------------------------
    Some letters are prohibited from origin program by Apple "AEIOUBSZ". (look pics)
    I authorized them in this version for test.
    Don't Use if you don't know
    This is not a crack of MacUnlock version, just this inspired me and I searched
    Just need a little usb key
    Archive Size: 389*Mo /.img Size: 494*Mo
  • anhbanxoi
    • Sep 2021
    • 180
    • VN
    Re: BBS MOD MxP APPLE BLACK BOARD SERIALIZER
    Same thing.
    • kevingill
      • Jun 2013
      • 152
      • England
      Nice one
      • kingzang
        • Jul 2022
        • china
        Boot the Mac from the USB tool,then the Mac reboot dirrectly,no nothing!
        • kevingill
          • Jun 2013
          • 152
          • England
          How did you create the USB stick?
          • kingzang
            • Jul 2022
            • china
            I Use RUFUS to create USB stick with download img file and my Mac is 2010 Mid 13 Macbook pro.
            Pls share me your step.
            Thanks!
            • Vincent Varga
              • Aug 2022
              Is this compatible with 820-3787-A boards?
              First off, I'm not a specialist, at best an amateur, and just hoping for some sanity check with you guys.
              A quick summary after 5 days of checking power rails and forums and board schematics (*I don't give up and can't afford a new mac):
              - found that macos security update has flashed wrong fw on the rom just before I installed a fresh ifixit battery
              - the fw installed was for macos 7.1 - 2006 ( have this in installation logs and pictures of os system and ofc no battery would be managed by wrong controller fw)
              -all hw components were fine;
              -re-installed new os, was lucky enough to get correct efi fw on it (the 443.140.2.0.0);
              - serial number was missing so I decided to use this software to flash serial number on it;
              - it looked fine after this flashing then I rebooted back into the OS Recovery mode and it confirmed the correct serial applied. I decided to have it shutdown instead of moving ahead with recovery proces. Now nothing is loading.
              No POST, no recovery, nothing.
              I have this mac since 2015. I really hate giving apple money.
              • kevingill
                • Jun 2013
                • 152
                • England
                I wouldn't have thought the software would kill your Mac.
                It's worked well for me.
                I'd open a new thread for this issue and report your voltage readings and S states.
                • Vincent Varga
                  • Aug 2022
                  Too many variables here, so not sure if this sw has fried the efi rom or maybe a wrong sequence missed by me (thinking maybe I should have done a PRAM reset at first reboot).
                  Just soldered a new rom correctly programmed and with sn written on it from ebay (my first solder so won't embarrass myself by posting pictures here ).
                  And it's alive. just needs an os re-install.
                  But long story short it all started with me not blocking that "apple security update" that set fw 162.X.X.X instead of 443.X.X.X.X
                  I'll make time to gather all logs and print screens I've documented and post this in some forums.
                  • patfon
                    • Dec 2020
                    • 5
                    • france
                    Great !! thanks fot tje job , merci
                    • anquach10
                      • Nov 2018
                      • usa
                      thanks a lot ,it works perfectly
                      • Reda123456
                        • Jan 2022
                        • 89
                        • iraq
                        • Repairing Tech
                        is its compatipe with a1706 macbook pro 2017 13 inch
                        • kevingill
                          • Jun 2013
                          • 152
                          • England
                          I wouldn’t have thought so, since it’s intended for the non T1/T2 chip models.
                          • .::iRizwan::.
                            Banned
                            • Apr 2016
                            • 63
                            • Pakistan
                            • Too Much
                            This software works for 2012-2017 MacBooks.
                            • sanoc
                              • Mar 2023
                              • df
                              Originally posted by anhbanxoi
                              Same thing.
                              please give me the software again.thank
                              • N-Steven
                                • Aug 2020
                                • Korea
                                This BBS does not work on the 2009-2011 Mac.
                                Can't make mods with older versions of BBS?(ex. 3T106 version)
                                • jamecollins
                                  • Jul 2023
                                  I've tried on macbook pro 2017, show boot menu but can't boot to USB.
                                  • Testingtesting
                                    • Aug 2023
                                    I can't figure out how to make the usb tool, please help! I just see two img files and a folder but nothing seems to allow me to make a bootable disk image, can't get Rufus b/c no windows just Mac OS
                                    • alexcanario
                                      • Jul 2019
                                      • Brazil
                                      Thanks for sharing
                                      • smalk
                                        • Sep 2023
                                        It really works, I restored the serial number on Air 2015. USB only with RUFUS
