BBS MOD MxP APPLE BLACK BOARD SERIALIZER
Okay thanks for your answer.
When I have everything I will do it.
But is the activation lock not server relation because of serialnumber?
Hi @Maxpower3, was it tested with the Late 2013 "Trash Can" Mac Pro (MacPro6,1)?
On my machine, it causes a black screen and a couple of restarts. After that, it chimes and returns to the boot screen.Last edited by zenon_brak; 11-17-2024, 03:05 PM.Comment
Thanks a TON! With all the other methods and images out there, for some reason this is the only one that has worked for me.
I even rolled back to Mojave!
I have a Mac Pro 2013 "Trash Can" (MacPro6,1) which I put a spare Apple SSD (256GB) and installed Mojave (because I thought Monterey wasn't allowing me to boot to the other image thumb drives I made).Comment
Used Disk Utility to restore the .IMG onto a thumbdrive, restarted and held down Option. Booted into the serializer.
After putting in the serial number (twice, one for verification), it went and checked the computer for 10 minutes and it said that there were no problems. Then I restarted and checked - I now have my serial number back!
Thanks again Maxpower3.Comment
*********** BLACK BOARD SERIALIZER ***********
Blank Board Serializer is mod by MxP !! Enjoy !!!
Setting serial number is too easy
" Only for all Mac models 2009 to 2017 "
This USB tool helps to:
Change the Serial Number (SSN) or add a new Serial Number.
It supports all type of Macs including MacBook, MacBook Pro, MacBook Air, iMac, Mac mini and Mac Pro (2009 to 2017).
* Use RUFUS to create USB key with .img
** The process is as simple as booting the Mac from the USB tool, type a new serial number and confirm.
--------------------------- WARNING--------------------------------------
Some letters are prohibited from origin program by Apple "AEIOUBSZ". (look pics)
I authorized them in this version for test.
Don't Use if you don't know
This is not a crack of MacUnlock version, just this inspired me and I searched
Just need a little usb key
Archive Size: 389*Mo /.img Size: 494*MoComment
Hi gents, I tried to run it on Macbook Pro A1278 (Early 2011), and also Macbook Air A1370 (Mid-2011), it worked!
But it couldn't work on Macbook Pro A1286 (Mid-2009), neither nor Macbook A1342 (Mid-2010), stuck in a black screen with a cursor, and then automatically restart after a while, can anybody help?Comment
Could anyone PLEASE help me understand step-by-step EXACTLY HOW can I make these folders and files downloaded from here bootable on usb stick via rufus?
I honestly have no clue how to do that. Thanks!Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by stefanbsThe laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?05-11-2025, 01:08 AM
Apple MacBook Pro 13" A1706 Logic Board 820-00923 Schematic & Board View...
Channel: Schematics and Boardviews
Apple MacBook Pro 15'' A1398 X435 051-00330 820-00138 Schematic & Board View
A1398 main board resistance measurements (user submitted no further details)...-
10-01-2024, 06:58 AM -
by breslerrHi, does anyone perhaps have the boardview schematic for an Apple Macbook Pro 2024 M4 A3401? Many thanks in advance. (I managed to find M3, but there are differences in the board layout)
Channel: Schematic Requests ONLY!
04-18-2025, 07:09 AM -
- Loading...
