Please need unlock 830 g8
dont touch the ec put it back.. flash the main bios
first boot press f10 reset bios to factory defaults and exit.Attached FilesComment
Hello, I need help to unlock an HP elitebook 830 g8, could you help me, thank you
elitebook 830 g8
SN: 5CG2410Z5B
board : 6050A3426501
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CG2410Z5B
Product #/SKU: 6C103EC#ABM
CT Number: PQSNP00WBH819I
Description: HP EliteBook 830 G8 Notebook
BuildID: 21WWCVDZ603#SABM#DABM
Feature Byte: 476J6S6b7B7H7M7R7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEmwn7nVngpDpnpqpr.Hy
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
here's your DMI:
BIOS LOCKED
HP ELITEBOOK 830 G8
PRODID 6A3M6AV
SN 5CG21508Y5
HP EliteBook 830 G8 Notebook PC
CT Number_6LGWQ0JWYG73BC
Serial_5CG21508Y5
Product_6A3M6AV4
Fearture byte_76J6S6b7B7H7M7Q7W7m7saBapaqauawb8bUcAdpdqeMfPguhKhkj4jhk8mEmVmwn7nVngpDpq.f3
Build Id_21WWCVET601#SUUW#DABBAttached Files
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
second chipAttached FilesComment
HereAttached Files
pls unlock my hp elitebook 830 G8
sn: 5CG152P2T
heres the backup.*****************
TNX A LOT.Last edited by SMDFlea; 09-14-2024, 05:46 AM. Reason: Attach files directly to your post in a zip or rar archive. Read the rules https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobComment
Attach files directly to your post in a zip or rar archive. Read the rules https://www.badcaps.net/forum/troubl...before-posting
hello. i need the bios password removed from this dump.
this is a HP Elitebook 830 G8
serial is: 5CG142C2FK
board is: CORVETTE-6050A3217501-MB-A01(A1)
this was dumped from next to m.2 connector,
bios firmware will be attached below. thank you to whoever helps me out.Attached FilesComment
post both fileComment
here's your DMI:
Serial Number: 5CG142C2FK
Product #/SKU: 4L804PC#ABA
CT Number: PKUHC00WBFTUAW
BuildID: 21WWCVCT601#SABA#DABA
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfPguhKhkjhk8mEmVmwnVng.NY
MAC Address : C8:5A:CF:38:00:83Attached FilesComment
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
Channel: BIOS Requests ONLY!
by remizbushkaHi sirs. please help
Dell Inspiron 5775 bios locked "Unlock Setup fail"
After generating the Password Recovery code, I go to the “Security” tab - “Locked Settings” - it says “Unlock Settings? I tried many wrong passwords and it shows an error to unlock settings [ Press any key ].
What I did:
I read the bios dump.
Downloaded the bios update to 1.6.0 from the official Dell website, extracted the dump from it, updated the bios, but the problem persisted. Please help me to solve the problem....-
by Syavko1Hello, help me. I need to unlock the BIOS on my laptop. HP Spectre x360 Convertible 14-ea0520na (2Z6W0EA)
I have access to Windows. Is it possible to unlock it through Windows? Do I need to unsolder the chip? -
ola boa tarde! será que conseguem ajudar! por incrível que aparente não consigo lembrar minha senha! da bios!
can help, i ty buy but in now i have without recurses in this country , are tryng unlock may admin unlock with serial ..my good, but are booting normaly in windows.
5ZQGXM3-8FC8
i forget my laptop up, is an alienware m15 r6 dell .
- Loading...
