Latitude E6530 - Trouble Extracting BIOS Image From EXE
  • grimacelord
    • Jan 2017
    • 383
    Hi folks,
    I'm having a hard time extracting this Dell BIOS. I have a Dell Latitude E6530 that has BIOS corruption and I need to reflash with CH341A programmer. I have already taken dumps of both the 4MB and 8MB chips on the motherboard.
    Service tag number for this model is: "JYDWYW1".
    Link to latest BIOS for this Service Tag: https://dl.dell.com/FOLDER05371360M/1/E6530A22.exe
    I have tried:
    • Simply extracting with 7zip
    • PFSExtractor
    • Using "/writeromfile, /writehdrfile, and /writehexfile" commands
    • Check Temp folder
    None of these methods got me the 2 files that I am after.
    I eventually was able to extract out a set of .bin files using a python script that was downloaded as part of the BiosUtilities collection on github. However, none of these 11 .bin files do not match the file size of my original (corrupted) dumps which should be 4MB and 8MB.
    In my desperation, I searched this forum and found someone with a similar problem and used the two BIOS files that was provided as a solution in their threads and flashed those. They did indeed allow the computer to POST, but the model is off and now I can't flash the correct BIOS from MS-DOS USB because the Dell thinks it's a different model than the BIOS .EXE is looking for. I guess I wasn't paying close enough attention and used a similar, but wrong model's BIOS. Ugh. But at least it did demonstrate how flashing a new BIOS fixed the original problem. I just need to flash the correct one.
    I think I just need to get those two files and then wipe both chips again and reflash with the correct files and I will be good to go. I just can't seem to figure out how to get the two files I need and I haven't encountered a Dell BIOS that I wasn't able to get the BIOS images from before, so this is kind of new territory for me.
    Thank you for your help.
    Edit: Attached original BIOS dumps
  • volinakis
    • Jan 2021
    • 2887
    • N/A
    Re: Latitude E6530 - Trouble Extracting BIOS Image From EXE
    extracted files from update exe. I used Dell-PFS-BIOS-Assembler-master from github. you have to merge both files and replace modules with UEFITool. Using FIT Tool to clean ME it will split files in right sizes.
    • grimacelord
      • Jan 2017
      • 383
      Hi. Thanks for the reply. Unfortunately, those files you extracted and zipped for me are the same files I was eventually able to get myself. I have no idea what to do with them to get a 4MB and 8MB file.
      I really appreciate you helping me though. Thank you!
      • volinakis
        • Jan 2021
        • 2887
        • N/A
        I told you, merge bios files and replace modules from full bios with extracted modules with UEFITool. Then perform a clean ME to full bios and FIT will split files. I will try to do it if you van't but I am a little bit busy so after 4-5hrs I will be able to help you.
        • grimacelord
          • Jan 2017
          • 383
          Ok thank you. I briefly started reading some guides about how to do that, but I've never had to do this before and right now, it all seems a bit over my head. I really appreciate your help and please, take your time with whatever you're working on now. I'll just watch this thread for your reply.
          Thank you again.
          • volinakis
            • Jan 2021
            • 2887
            • N/A
            Thank you again.
            ok, try this and let me know if works. your bios has some errors, I replaced Bios Region with extracted from update and performed a clean ME. New bios has no errors, i hope will works.
            • grimacelord
              • Jan 2017
              • 383
              Thank you so much! Those files worked perfectly. Everything is working as it should be now. Thanks again!!!
              • volinakis
                • Jan 2021
                • 2887
                • N/A
                you are welcome.
                • Amber TC
                  [NOT A RESCUE BIOS] Dell Latitude E6530 Rare Factory BIOS (Revision A86)
                  by Amber TC
                  ⚠️ Not a Rescue BIOS. Flash at Your Own Risk. ⚠️
                  This is not A17.
                  This is not listed on Dell's support site.
                  This is an unreleased internal firmware revision recovered from a university loaner Latitude E6530... and it possibly bricked the system it came from.
                  It is from the 8 MB Winbond W25Q64 chip. Could be nothing burger but given the anomalies this is a very interesting firmware dump.
                  Firmware collectors and reverse engineers might find this useful, It contains certs, modules, and DXE drivers not present in A17. This is likely...
                  04-17-2025, 03:54 PM
                • Sathsul
                  Dell Latitude 5431 issues with dumping bios
                  by Sathsul
                  So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                  The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                  However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                  10-28-2025, 07:49 AM
                • TripTop
                  Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                  by TripTop
                  Hi
                  i have dell latitude E7270 with following symptoms:
                  - takes long time to restart.
                  - sometimes powers on and then off
                  - sometimes while working it just dies,
                  From googling online bios clean could possible resolve this?
                  i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                  As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                  I reinstall...
                  09-09-2024, 02:05 PM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • gizaha
                  by gizaha
                  02-13-2024, 07:18 AM
