HP 640 G4 BIOS Security Device Problem
  • lekvilius
    • Jul 2018
    • 3
    Hello!, i've got Hp 640 g4 that recently had bios reflash by someone else due to having password and now when you turn it on after 30 seconds of black screen it posts with message: security device problem. I don't have original bios to flashback and just remove password. Does anyone know how to solve this bios problem? Also serial is different in bios than it is on the bottom cover so maybe that's the problem?
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: HP 640 G4 BIOS Security Device Problem
    This error may be caused by incorrect DMI information, try using HP DMI Tool NBDmiFit to declare it again.
    https://www.badcaps.net/forum/showthread.php?t=69204
    • lekvilius
      • Jul 2018
      • 3
      I tried few versions of NBDmiFit, i can boot to it, but can't unlock to MPM mode to change serial and etc. Any other way to change serial and UID please? Or how to unlock it to MPM mode?
      • hoaca388
        Badcaps
        • Jan 2022
        • 12441
        Have you tried it yet?
        • 2667388155388299
          Andy DE-BW
          • Jan 2024
          hi, i had 2 Posts here and actually they habe been deleted. Why?
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • Matias1997caba
          Problem with Dell pp35l bios
          by Matias1997caba
          Hello everyone! I'm having a problem with the BIOS of a Dell PP35L motherboard (DA0RM5MB8E0 Rev:E Y509R Rev:A00). It powers on, beeps 5 times, then 6 times, but there's no display. The problem is that it has two 16MB BIOS files, and all the ones I found online are 1MB and 4MB. I flashed them anyway, but with those BIOS files, the fan doesn't even turn on. Any help would be greatly appreciated! I've attached the BIOS files. Model: Dell PP35L.. Mother DA0RM5MB8E0 Rev:E Y509R Rev:A00. Service Tag: GRZR9M1...
          11-26-2025, 08:33 AM
