Request Lenovo X1 Gen6 BIOS
  • doa379
    • Aug 2021
    • 19
    • US
    I managed to brick a X1G6 using the autopatcher method for clearing a SVP. Clearly the state of the firmware was not I could have guessed from the instructions given to clear the SVP.
    If I remove the CMOS battery the unit power cycles multiple times. The power LED is on at the initial state for a mere second then the unit goes off.
    I tried flashing the original BIOS back but the symptoms remain and the system doesn't POST..
    My feeling is I have to clear more of the firmware.
    Anyone know what I'm talking about?
  • hoaca388
    • Jan 2022
    • 11131
    • Viet Nam
    Re: Request Lenovo X1 Gen6 BIOS
    New bios file :
    Become a Badcaps supporter
    Thanks to all supporters.
    • doa379
      • Aug 2021
      • 19
      • US
      Originally posted by hoaca388
      New bios file :
      Thanks.
      Did not work. System continues to power cycle on then off at 1-2 sec intervals.
      What was the origin of this file BTW?
      • hoaca388
        • Jan 2022
        • 11131
        • Viet Nam
        Originally posted by doa379
        Thanks.
        Latest suggestion
        • doa379
          • Aug 2021
          • 19
          • US
          Thank you for preparing this binary. I have not been able to test it yet. I was using my clip so much that it wore out and no longer works. Until I get a replacement clip, I may not be able to test.
          Anyway, this binary you have provided clears some ME flags. Do I flash the same winbond chip (W25Q128JV) with this binary? Do you think it will work? Can you tell me if this operation will reset the security flags in the EC?
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • grimacelord
            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
            by grimacelord
            Hello there.
            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
            History:
            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
            I searched for this error online and discovered...
            03-15-2023, 03:29 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • beogeek
            Lenovo Yoga Slim 7 14APU8 Bios Request
            by beogeek
            I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
            Attached is the bios dump in the state I received it...
            10-24-2024, 12:54 PM
          • jendkkd jeje
            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
            by jendkkd jeje
            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
            10-11-2024, 03:12 PM
