Asus GL703VD need dump
  • khaly
    • Jan 2015
    • 22
    I need a bios dump for a DABKNMB28A0 REV.A
    Asus GL703VD
  • hoaca388
    Badcaps
    • Jan 2022
    • 11733
    Re: Asus GL703VD need dump
    Attach your original dump bios file.
    • khaly
      • Jan 2015
      • 22
      ok
      • hoaca388
        Badcaps
        • Jan 2022
        • 11733
        Asus GL703VD
        • khaly
          • Jan 2015
          • 22
          Thank you.
          • zambiee99
            • Feb 2014
            • 7
            • romania
            Hi. Can someone please help me to remove bios pw? I found one with no password, and I tryed to replace from 21E170 to 27FFFF but it contains also the password. The one which I found was not region free, now I have slow boot. Thanks in advance
            I forgot to mention the model: GL703VD, MB: DABKNMB28A0 REV A, SN: J1N0CX02T932015
              • 20888
              please type and post the laptop serial number as well https://www.badcaps.net/forum/troubl...before-posting
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Anchar777
                ASUS P1412CE need BIOS DUMP
                by Anchar777
                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                06-26-2025, 03:39 AM
