Asus GL703VD need dump
  • khaly
    • Jan 2015
    • 22
    • Romania
    I need a bios dump for a DABKNMB28A0 REV.A
    Asus GL703VD
  • hoaca388
    Badcaps
    • Jan 2022
    • 11164
    • Viet Nam
    Re: Asus GL703VD need dump
    Attach your original dump bios file.
    Any donations to Badcaps are welcome. Become a Badcaps supporter >>>>> click this link to donate <<<<< Thank you to all the supporters. -- -------------------------------------------------------------------------------------------------------------------------------------------------------------
    • khaly
      • Jan 2015
      • 22
      • Romania
      ok
      • hoaca388
        Badcaps
        • Jan 2022
        • 11164
        • Viet Nam
        Asus GL703VD
        • khaly
          • Jan 2015
          • 22
          • Romania
          Thank you.
          • zambiee99
            • Feb 2014
            • 7
            • romania
            Hi. Can someone please help me to remove bios pw? I found one with no password, and I tryed to replace from 21E170 to 27FFFF but it contains also the password. The one which I found was not region free, now I have slow boot. Thanks in advance
            I forgot to mention the model: GL703VD, MB: DABKNMB28A0 REV A, SN: J1N0CX02T932015
              • 20300
              please type and post the laptop serial number as well https://www.badcaps.net/forum/troubl...before-posting
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • kcp0085
                Request BIOS dump for ASUS FA617NS-A16.R77600
                by kcp0085
                Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
                I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
                Specs:
                - ASUS TUF FA617NS-A16
                - CPU: AMD Ryzen 7
                - BIOS chip: Winbond W25Q16JVSIQ (2MB)
                If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
                Thanks in advance!​
                05-02-2025, 12:52 AM
