HP 840 G1 Completely wrong system info
  • Andreasbest
    • Aug 2014
    • 1169
    • Hellas ( Greece )
    Hello.
    I received a 840 G1 with completely wrong system info in BIOS.
    Serial Number and everything is wrong, even the Model is wrong (written as 850 G1)
    How can i reset these info?
    Thank you!
    • 20933
    Re: HP 840 G1 Completely wrong system info
    Originally posted by Andreasbest
    Hello.
    Thank you!
    https://www.badcaps.net/forum/showthread.php?t=103526 ->
    https://www.badcaps.net/forum/showpo...43&postcount=5
    HP Bios Config Utility
    • Andreasbest
      • Aug 2014
      • 1169
      • Hellas ( Greece )
      I have the HP config utility BUT to unlock the edit option the laptop must be in MDM mode, no matter how much i tried i never managed to set laptop in MDM mode
        • 20933
        Heres a couple of videos that might help https://www.badcaps.net/forum/showpo...&postcount=137
        • Andreasbest
          • Aug 2014
          • 1169
          • Hellas ( Greece )
          I tried the .txt way but the MDM remains locked.
            • 20933
            Theres a jpeg picture in the 1st attachment with instructions
            Manufacture Programming Mode in Unlock mode MPM.zip https://www.badcaps.net/forum/showthread.php?t=69204
            • Andreasbest
              • Aug 2014
              • 1169
              • Hellas ( Greece )
              Yes i know, this is exactly what i have tried, still locked.
              • Andreasbest
                • Aug 2014
                • 1169
                • Hellas ( Greece )
                Tried again as we speak, set the * to Unlock and erase it from Lock, set it back with the command and restart the laptop, still locked.
                • Andreasbest
                  • Aug 2014
                  • 1169
                  • Hellas ( Greece )
                  Just noticed is a 840 G2.
                  I dump the EC file (with wrong information), how can i edit it and reflash it? UEFI Tool?
                  • Andreasbest
                    • Aug 2014
                    • 1169
                    • Hellas ( Greece )
                    All 850 G2 EC bios dumps that are on google have wring EC from 850 G1
                      • 20933
                      Post the motherboard part number
                      • Andreasbest
                        • Aug 2014
                        • 1169
                        • Hellas ( Greece )
                        730810-001
                          • 20933
                          730810-001
                          Post the long motherboard part number as well,such as 6050A2560201-MB-A03
                          • Andreasbest
                            • Aug 2014
                            • 1169
                            • Hellas ( Greece )
                            I don't see any number like this on motherboard, i see a 6070B0676404 on the chassis but since the motherboard is G1 and the chassis G2 (seems like the customer has built a Frankestein machine here) this number is not relevant to motherboard.
                            • DynaxSC
                              ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                              by DynaxSC
                              I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                              This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                              Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                              02-10-2025, 04:52 PM
                            • double_DD
                              HP Probook 455 G8 charging but doesn't turn ON
                              by double_DD
                              Unfortunately I cannot/don't know how to edit my last query, so I'll create another one instead.
                              So I've received this laptop to try and fix it. There were 2 blown components - small inductor and cap, both on Vin (main power rail) on the IN pins of the 0.75V chip (SY8388RHC). I've replaced that chip and the nearby 0.75V_DEEP_SUS (same type), and of course both of blown components. There was still a short on 3V coil, which went away when I replaced PI3DPX1207C chip next to usb-c port (as it was overheating). Luckily I have older non-working 455 G7 for the spare parts....
                              03-13-2025, 05:06 AM
                            • kondou
                              Need ThinkPad Config Information Update v1.02 or Lenovo Maintenance Utility V2.02
                              by kondou
                              I need ThinkPad Config Information Update Utility v1.02(or later) or Lenovo Maintenance Utility V2.02(or later).
                              These software can write MEC1633 eeprom.
                              X240,X250,T440,T450,etc... serial number can fix.
                              I have serial invalid X1 Carbon 5th.
                              I want repair it.
                              This ThinkPad is MEC1653.
                              I want try that.
                              Thanks.
                              11-08-2019, 10:12 PM
                            • chth96
                              What is name of IC which is written "601Km" on its surface?
                              by chth96
                              Hello.
                              I have T12-952 soldering station which is not able to display any screen But When I power on it, iron become hot.
                              I desolder some components to check whether it have been faulty or not, But When I tried to desolder an IC Which is written "601Km" on the surface,I broke leftmost pin like attached photos.
                              I use Mini Drill in order to peel off plastic suface but I cannot found copper sheet which is supposed to be pin3.
                              What is name of IC which is written "601Km" on the surface?
                              and Is there any...
                              09-28-2024, 11:19 PM
                            • Jeff'sTech
                              Dell Latitude 7420 BIOS Unlock Gone Wrong
                              by Jeff'sTech
                              Hello everyone.
                              I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                              11-08-2023, 03:30 PM
