DA0U36MB6D0 rev D
  • pippo_one
    • Aug 2010
    • 120
    • Vicenza
    DA0U36MB6D0 rev D
    Hi everyone, I have a problem with my Hp15-B040SL
    with a main DA0UMB6D0 rev D, when I turn it on I have no signal on the screen and after 10/15 sec the fan starts spinning at maximum rpm but remains on.
    The cpu is cold and I don't detect any voltage at the coil "PL17" "+ VCC core".
    I'll post the bios obtained.
    Thank you in advantage for help to me
  • peste
    • Dec 2016
    • 12954
    • ROMANIA
    Re: DA0U36MB6D0 rev D
    try..
    • hoaca388
      Badcaps
      • Jan 2022
      • 11888
      HP Pavilion Sleekbook 15
        • 21175
        Bios extracted from update sp76891 + DMI+Key.
        • pippo_one
          • Aug 2010
          • 120
          • Vicenza
          Hi I have tried all three bios, but the problem persists turns on does not send a signal to the video and the fan goes to maximum after 15 sec, cpu and gpu cold, other suggestions?
          Thank you
          • peste
            • Dec 2016
            • 12954
            • ROMANIA
            Thank you
            maybe bios is not the problem ... check why there are no voltages on the CPU and GPU ...
            • trepachka
              Yoga 9 14ITL only left fan spinning
              by trepachka
              Hi, I have this laptop that had multiple issues: a bad USB-C chip, a bad power regulator, a bad ALC3306 chip. The latter stumped me because I never had an audio chip cause any issues. Yet, it was heating up to 80c.
              After all of these got replaced, the laptop is working again but only the left fan is spinning upon heat buildup. The right one is not spinning ever. I had a spare heatsink/fan assembly which I installed but the problem is not going away. So, the fan itself is ok. I checked pins on the fan connector and it does get 5v and 3.3v.
              I don't think it's the thermal...
              11-07-2023, 03:09 AM
            • pabloroggeri
              Lenovo V360, no detect battery
              by pabloroggeri
              Hi friends!
              It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different...
              07-28-2022, 08:18 AM
            • tikanot
              msi GP63 gtx not detect and keyboard mistake
              by tikanot
              Hello i have a msi GP63 and the gtx 1060 is not detect in the bios and not detect in windows , i have flash the vbios with programmer and same mistake, i have the ec do mistake with keyboard key not work or keyboard not work , i know i have to chance the ec but it's possible the ec do the gtx not detect in bios and in windows? i have check the voltage of the vga and it's good the die of the gpu is little hot at used
              04-21-2022, 10:01 AM
            • pooya_pm
              ASUS PRIME Z690-P WIFI D4 BIOS ms no detect
              by pooya_pm
              ASUS PRIME Z690-P WIFI D4 BIOS m2 no detect
              pls hellp and fix bios...
              12-26-2024, 03:32 AM
            • mondogen
              Lenovo G50-70 power on but no display and fan not spinning
              by mondogen
              Hi everybody, I'm a beginner and I've got a Lenovo G50-70 with NM-A271 rev 1.0 mobo.
              It powers on BUT:
              * no display
              * fan not spinning
              * power led is on and battery led too (if inserted)
              * no power consumption without battery, with battery 0.27A
              * no shorted coil to ground
              * +3VALW, +5VALW and +3VALW_PCH are present
              * 3.3V on bios pin 1 is present
              * 1.9V on PL302 coil
              * I tried to flash bios with external programmer (CH341A) e nothing changed.
              Any suggestions?...
              11-11-2024, 11:04 AM
