ASUS PRIME Z690-P WIFI D4 BIOS ms no detect
  • pooya_pm
    • Jan 2021
    • 254
    • iraq
    ASUS PRIME Z690-P WIFI D4 BIOS m2 no detect
    pls hellp and fix bios
  • noname2024
    • Aug 2024
    • 274
    • CỎ MỸ XỊN
    try
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • throwaway327
      by throwaway327
      Model No: RC72LA
      Serial No: SBNVKD001014459
      06-18-2025, 05:52 PM
