Lenovo V360, no detect battery
  • pabloroggeri
    Electronic
    • Apr 2015
    • 90
    • Argentina
    Hi friends!
    It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different bios file than the one published in the forum to test.
    Motherboard: HannStar LA36 MB 09939-1
    09939-1
    48.4JG01.011
    IC charguer : BQ24745
    EC: NPCE781EA0DX
    Bios version: 2DCN16WW
    EC version : 2DEC02WW
  • mon2
    • 14370
    Re: Lenovo V360, no detect battery
    Unable to comment on the bios issues but for the battery pack - investigate the voltages on EACH pin on the battery connector.
    Specifically, we are interested to confirm the SMBUS / I2C (SDA & SCL) lines are ok since they are used by the logic board to communicate with the BMS (battery management system). This will be a good start.
    • Udemzy
      • May 2017
      • 161
      • Guatemala
      Since you already got an idea of where the fault might come from,i'll suggest you do that first or you can measure the SDA and SCL line with your oscilloscope or measure the bios chip pins with the oscilloscope.
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • mrkmpn
        Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
        by mrkmpn
        Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
        This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
        03-13-2024, 01:54 PM
      • pabloroggeri
        Lenovo V310-15ISK - It doesn't work after changing the battery
        by pabloroggeri
        Good guys. I changed the battery to a Lenovo V310-15ISK.
        The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
        When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
        08-23-2024, 12:01 PM
