Help hp probook 430 g7 bios pw
  • shaggy90
    • Oct 2022
    • 6
    • Italia
    Re: Help hp probook 430 g7 bios pw
    Flash new bios , password not remove
    • hoaca388
      Badcaps
      • Jan 2022
      • 12419
      post the main bios file
      • shaggy90
        • Oct 2022
        • 6
        • Italia
        This is the bios backup thanks
        • hoaca388
          Badcaps
          • Jan 2022
          • 12419
          This is Ec file, post your main bios file, you still have 2nd SPI chip.
          • hfyxn
            • Mar 2023
            • 3
            • ru
            hi guys!
            on dumping (my friend - service guy - did it) both chips the resulting files appeared 1mb in size. no idea why - maybe programming device was not set up correctly.
            wb chip has been re-soldered and checked - probook booted correctly.
            gc chip died after re-solder (caps lock on power connection and nothing more) and has been replaced with another wb with flashing its dump. booted ok although some bios update has been done automatically.
            probook now seems working without troubles (of course bios password is in its place).
            i realized 1mb dump size only after all that - when checked dumps at home.
            does anybody know what could happen on re-flashing replacement chip (gd is bios itself, correct?) with incomplete dump? i suspect that probook might fix corrupt bios with its surestart feature and now the bios is exactly the same as before.
            or if the bios is partially healthy then how can i fix it? what if i dump another's probook of the same model and add my part of origibal dump?
            • hfyxn
              • Mar 2023
              • 3
              • ru
              #26
              hello guys! anybody home?
              • TESLAWEILER
                • Apr 2023
                #27
                Hello All,
                I have succecced to unlock bois with HxD (NvramActiveRegn), but every time after boot gives me this message (hp endpoint security controller problem )
                Could you please help me to remove PW properly and fix "hp endpoint security controller problem"
                attched files contains orginal dumb and unlocked one.
                • userraj
                  • Aug 2023
                  Hi, I need BIOS unlock bin file for:
                  • gsmmardi
                    • Aug 2015
                    • 15
                    • Morocco
                    #29
                    hello masters! can someone help me out, admin password heres my files, Thanks in advance for the one who can help me out
                    • minhdigital
                      • Nov 2022
                      • 765
                      • Vietnam
                      #30
                      Serial ??
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #31
                        There's no such model as "hp probook 840 G7". Your model is HP ProBook 430 G7 according to the bios dump in your post.
                        You MUST:
                        • Post under a related thread if it exists
                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
                        Become a Badcaps supporter
                        Thanks to all supporters.
                        • gsmmardi
                          • Aug 2015
                          • 15
                          • Morocco
                          #32
                          Hp probook 430 G7
                          Prodid 1B7N2ES#AB6
                          S/N # 5CD0288C7J
                          ​da0x8lmb8d0-rev-d
                            SMDFlea commented
                            Editing a comment
                            Posts moved to 430 G7 bios pw thread. Please try to get the correct model first before posting here again,and read all of the rules !
                        • gerlach
                          • Jan 2020
                          • 16
                          • Poland
                          #33
                          Hello.
                          I have a problem after removing my password. The password was removed using RCUnlocker. After uploading the unlocked batch, a message appeared HP Endpoint Security Controller problem.
                          Please help me get rid of this message.​
                        • m.sabry2110
                          • Oct 2017
                          • 134
                          • egypt
                          #34
                          Try
                          • gerlach
                            • Jan 2020
                            • 16
                            • Poland
                            #35
                            Originally posted by m.sabry2110
                            Try
                            Unfortunately, it didn't bring anything. It's still the same. After uploading the batch and running it, it updates and after another restart the problem is still there.​
                            Probook 430 G7
                            ProdID 3J931EC#UUW
                            S\N #5CD02526FR
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12419
                              #36
                              Probook 430 G7
                              ProdID 3J931EC#UUW
                              S\N #5CD02526FR
                              CCC
                              • gerlach
                                • Jan 2020
                                • 16
                                • Poland
                                #37
                                CCC
                                Everything is back to normal. Thank you very much Hoaca388
                                • OMENA
                                  • Oct 2023
                                  • Kenya
                                  #38
                                  I am having the same issue with HP ProBook 430 G7 can you share what steps you used to get rid of the "HP Endpoint Security Controller Problem"
                                  • fiabo89
                                    • Nov 2019
                                    • 14
                                    • Italia
                                    #39
                                    hello everybody i need password unlock for my hp THANK YOU
                                    HP ProBook 430 G7
                                    ProdID 8V739EA#ABZ
                                    S/N 5CD1129XD6
                                    Mainboard model DA0X8LMB8D0 REV D
                                    MODEL X8L
                                    • Eric assenga
                                      • Jan 2023
                                      • 31
                                      • Tanzania
                                      #40
                                      password removing for hp 430 g7 10gnth
                                      • peste
                                        peste commented
                                        Editing a comment
                                        merged post
                                    • studdy05
                                      Bricked HP Probook 450 G7 Bios questions
                                      by studdy05
                                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                      Ive got...
                                      07-08-2025, 09:24 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • pirati
                                      by pirati
                                      10-27-2025, 04:20 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • the_raz
                                      Need (unlocked) bios for HP Probook 450 G3 Notebook
                                      by the_raz
                                      I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                      Laptop number 1:
                                      Model: HP ProBook 450 G3
                                      Motherboard part number:...
                                      12-17-2024, 03:37 PM
