Flash new bios , password not remove
Help hp probook 430 g7 bios pw
Re: Help hp probook 430 g7 bios pw
post the main bios file↵
https://www.badcaps.net/donateComment
hi guys!
on dumping (my friend - service guy - did it) both chips the resulting files appeared 1mb in size. no idea why - maybe programming device was not set up correctly.
wb chip has been re-soldered and checked - probook booted correctly.
gc chip died after re-solder (caps lock on power connection and nothing more) and has been replaced with another wb with flashing its dump. booted ok although some bios update has been done automatically.
probook now seems working without troubles (of course bios password is in its place).
i realized 1mb dump size only after all that - when checked dumps at home.
does anybody know what could happen on re-flashing replacement chip (gd is bios itself, correct?) with incomplete dump? i suspect that probook might fix corrupt bios with its surestart feature and now the bios is exactly the same as before.
or if the bios is partially healthy then how can i fix it? what if i dump another's probook of the same model and add my part of origibal dump?Comment
Hello All,
I have succecced to unlock bois with HxD (NvramActiveRegn), but every time after boot gives me this message (hp endpoint security controller problem )
Could you please help me to remove PW properly and fix "hp endpoint security controller problem"
attched files contains orginal dumb and unlocked one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi, I need BIOS unlock bin file for:Attached Filesif you find these attachements useful please consider making a small donation to the site
hello masters! can someone help me out, admin password heres my files, Thanks in advance for the one who can help me outAttached Filesif you find these attachements useful please consider making a small donation to the site
There's no such model as "hp probook 840 G7". Your model is HP ProBook 430 G7 according to the bios dump in your post.
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hello.
I have a problem after removing my password. The password was removed using RCUnlocker. After uploading the unlocked batch, a message appeared HP Endpoint Security Controller problem.
Please help me get rid of this message.Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
CCCAttached Filesif you find these attachements useful please consider making a small donation to the site
hello everybody i need password unlock for my hp THANK YOU
HP ProBook 430 G7
ProdID 8V739EA#ABZ
S/N 5CD1129XD6
Mainboard model DA0X8LMB8D0 REV D
MODEL X8LAttached Filesif you find these attachements useful please consider making a small donation to the site
password removing for hp 430 g7 10gnthAttached Filesif you find these attachements useful please consider making a small donation to the site
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by the_razI'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
Laptop number 1:
Model: HP ProBook 450 G3
Motherboard part number:...-
- Loading...
