HP probook 445 g8 bios pass remove
Every donation made will go towards server fees and maintenance costs.Comment
There will be EfiSystemNvDataFvGuid under BIOS region. There you will find VSS2 store.
ProBook 445 G8 Notebook PC
CT Number : 6LGXT0C81FK3WS
Serial : 5CD1485N1L
Product : 4K784EA#ABD
Build Id : 21WWPDCT601#SABD#DABD
Fearute byte :3X476J6S6b7B7J7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPguk8mEn7nW.5fComment
Hi all, could someone remove password please
SN: 5CD1487JN7Attached Filesif you find these attachements useful please consider making a small donation to the site
Actually could you use those files please I wasn't happy with the first backup.TAAttached Filesif you find these attachements useful please consider making a small donation to the site
Try now and Give FeedbackAttached Filesif you find these attachements useful please consider making a small donation to the site
When powering on this HP Probook 445 G8 laptop, it shows SureStart error
"HP Sure Start detected an unauthorized change to the Secure Boot Keys. The key was restored automatically and there is no further action required. The repeated occurrence of this problem indicates a security problem and should not be ignored."
I cannot enter bios or change bootable device.
Here is dump of SPI BIOS
HP ProBook 445 G8
ProdID 2U740AV
S N # 5CD1383L13Attached Filesif you find these attachements useful please consider making a small donation to the site
bumpWhen powering on this HP Probook 445 G8 laptop, it shows SureStart error
HP ProBook 445 G8
ProdID 2U740AV
S N # 5CD1383L13
(@peste, i noticed this thread, but title was about password removal so i thought it would be considered thread hijacking.)Comment
Hi i have a HP Probook 445 G8 Ryzen that has and error message of warning your system is not fully configured please contact hp support.
here's my BIN file TIA
HP ProBook 445 G8
ProdID: X9QKU5#ABA
S N # 5CD0462HF1
hi flash spiAttached Filesif you find these attachements useful please consider making a small donation to the site
رد: إزالة BIOS من جهاز HP probook 445 g8
in English please...Attached Filesif you find these attachements useful please consider making a small donation to the site
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by PhadDear All,
Hope that this post is at the right place of the forum.
I am seeking help and technical advice to remove bios admin password from HP ProBook 4520s.
The laptop is operating normally and, I am not facing any major issue with it except; the bios admin password that I found about by coincidence only few weeks back.
As the laptop is operating normally, I am reluctant to take it to a workshop to de-solder the bios chip in order to read it by an external programmer, as I am not an expert in doing such a thing.
After...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
