ASUS K750L BIOS Reuest
  • shiriffsm
    Banned
    • Aug 2019
    • 35
    • 87116973284
    Hello Every one Please i need bios bin file for ASUS K750L
    MotherBoard : X750LN MAINBOARD REV:2.0
  • Verlengsnoer
    • Sep 2016
    • 109
    • Netherlands
    Re: ASUS K750L BIOS Reuest
    try this one
    • shiriffsm
      Banned
      • Aug 2019
      • 35
      • 87116973284
      Originally posted by Verlengsnoer
      try this one
      thank you, it's not working. now it turns on but no display, and when i try to turn it off its turns on imediately automatically
        • 20286
        Post pictures of any barcode stickers,like the ones in this thread https://www.badcaps.net/forum/showthread.php?t=96604 ,or if there isn`t a barcode sticker look for a square QR code
        • shiriffsm
          Banned
          • Aug 2019
          • 35
          • 87116973284
          this is the sticker
          • shiriffsm
            Banned
            • Aug 2019
            • 35
            • 87116973284
            can anyone help me please
            • peste
              • Dec 2016
              • 12230
              • ROMANIA
              post the original laptop bios
              • shiriffsm
                Banned
                • Aug 2019
                • 35
                • 87116973284
                This is my original Dump
                • peste
                  • Dec 2016
                  • 12230
                  • ROMANIA
                  try..
                  • Wilfried
                    • Sep 2019
                    • 79
                    • Cameroun
                    try..
                    Thanks you
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • lrouw84
                      by lrouw84
                      Hi there,
                      01-28-2023, 01:31 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
