HP 15s-eq0023np bios corrupted
  • Andre Kinetic Dimension
    • Feb 2019
    • 7
    • Portugal
    Hi people!
    I have this computer just come in, costumer stated that it was updateing BIOS and when it rebooted it apears a message stating that BIOS CURRUPTION DETECTED and keep retrying to recovery flash, but it fails and is stuck in this loop. I do not do this repair often and do not have a clena dump, nor can I find one! Can anyone help? dump file is uploaded
    HP 15s-eq0023np - board model: 0P5W (DA0P5EMB6E0 Rev:E) S/N: 5CD0457DNX
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    Re: HP 15s-eq0023np bios corrupted
    Try and report
      • 21692
      Originally posted by hoaca388
      Try and report
      You missed the featurebyte at 1000h and the win key at 8000h
      • hoaca388
        Badcaps
        • Jan 2022
        • 12281
        Thank you !
        File updated :
          • Feb 2019
          • 7
          • Portugal
          Thank you all! It works, the PC no longer say that the BIOS is corrupted. Is it possible to disable the "Manufacture Programming mode is in unlock mode" message ? how can I do it?
            • 21692
            It will lock itself after about 30 reboots or so, or use HP BCU
            https://www.badcaps.net/forum/showthread.php?t=69204
            Manufacture Programming Mode in Unlock mode MPM.zip
            • microlab
              • Nov 2015
              • 12
              • italy
              tnx
              • REpairAT
                • Nov 2020
                • 143
                • Austria
                There's are short video, quite helpful, worked for me
                https://www.youtube.com/watch?v=r2ubpyeUOB4
                Thank you all!
                • FalconPunch
                  Surface Pro X 1876 Bios corrupted
                  by FalconPunch
                  Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                  Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                  08-09-2025, 03:56 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • TylerHyde21
                  Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                  by TylerHyde21
                  Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                  I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                  I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                  This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                  06-29-2024, 10:38 AM
                • Loli Popu
                  DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 08:29 AM
                  by Vesko356
                  08-11-2023, 03:27 AM
