Asus GX501VSK bios bin request
  • lint4u
    • Nov 2013
    • 125
    • lint4u
    Hi Guys
    Please help me the bios for asus gx501vsk because the laptop already dead and no backup for this moment
    Thank you for the help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12280
    Re: Asus GX501VSK bios bin request
    Try this file, hope it work well.
    • lint4u
      • Nov 2013
      • 125
      • lint4u
      Thank you very much and i will post the result later
      • lint4u
        • Nov 2013
        • 125
        • lint4u
        The file not working sir.... thanks
        • lint4u
          • Nov 2013
          • 125
          • lint4u
          The laptop only fan spinning but no image appears
          • hoaca388
            Badcaps
            • Jan 2022
            • 12280
            Try with clear ME file.
            • lint4u
              • Nov 2013
              • 125
              • lint4u
              Thank you later i post the result
              • lint4u
                • Nov 2013
                • 125
                • lint4u
                Apologize to make you busy
                But the file still not working, same results.
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  try and report
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12280
                    Sorry , i have no way.
                    • lint4u
                      • Nov 2013
                      • 125
                      • lint4u
                      Originally posted by Claudiomfa
                      try and report
                      I'm not lucky this moment, if the file are working,
                      i think maybe the chip are faulty
                      Hystory:
                      >>> First time the bios got error and then i try to update
                      after 75% updates the laptop hang then after that it restart
                      • lint4u
                        • Nov 2013
                        • 125
                        • lint4u
                        It's OK Sir
                        btw thank you so much for the quick response
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • skurvysyn
                          BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                          by skurvysyn
                          laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                          original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                          01-08-2025, 04:45 PM
                        • skipron.rm
                          ASUS Zephyrus GX701LXS BIOS request
                          by skipron.rm
                          Hello everyone, trust you're doing well.
                          I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
                          I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
                          However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
                          The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
                          My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
                          Badcaps - Capacitor Search Engine & Electronics Repair Forum
                          12-11-2023, 06:12 PM
                        • ArkzG
                          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                          by ArkzG
                          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                          What I currently have available:
                          - Model: FA506NF (2021)
                          - BIOS chip: GD25LQ16 (16Mbit/2MB)
                          - Tools: CH341A programmer ready to use
                          Does anyone have either a clean 2MB .bin dump of this model,...
                          09-26-2025, 09:34 PM
