Asus GX501VSK bios bin request
  • lint4u
    • Nov 2013
    • 115
    • lint4u
    Hi Guys
    Please help me the bios for asus gx501vsk because the laptop already dead and no backup for this moment
    Thank you for the help
  • hoaca388
    Badcaps
    • Jan 2022
    • 11736
    Re: Asus GX501VSK bios bin request
    Try this file, hope it work well.
    • lint4u
      • Nov 2013
      • 115
      • lint4u
      Thank you very much and i will post the result later
      • lint4u
        • Nov 2013
        • 115
        • lint4u
        The file not working sir.... thanks
        • lint4u
          • Nov 2013
          • 115
          • lint4u
          The laptop only fan spinning but no image appears
          • hoaca388
            Badcaps
            • Jan 2022
            • 11736
            Try with clear ME file.
            • lint4u
              • Nov 2013
              • 115
              • lint4u
              Thank you later i post the result
              • lint4u
                • Nov 2013
                • 115
                • lint4u
                Apologize to make you busy
                But the file still not working, same results.
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  try and report
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11736
                    Sorry , i have no way.
                    • lint4u
                      • Nov 2013
                      • 115
                      • lint4u
                      Originally posted by Claudiomfa
                      try and report
                      I'm not lucky this moment, if the file are working,
                      i think maybe the chip are faulty
                      Hystory:
                      >>> First time the bios got error and then i try to update
                      after 75% updates the laptop hang then after that it restart
                      • lint4u
                        • Nov 2013
                        • 115
                        • lint4u
                        It's OK Sir
                        btw thank you so much for the quick response
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • skurvysyn
                          BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                          by skurvysyn
                          laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                          original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                          01-08-2025, 04:45 PM
                        • skipron.rm
                          ASUS Zephyrus GX701LXS BIOS request
                          by skipron.rm
                          Hello everyone, trust you're doing well.
                          I'm currently facing an issue with my ASUS Zephyrus GX701LXS, as it isn't posting.
                          I've downloaded the latest BIOS version, "GX701LXS-AS.311" (v.311), from the ASUS website.
                          However, there's a challenge – the file size exceeds the capacity of the BIOS chip, making it impractical for writing.
                          The current BIOS dump ("GX701LXS.307 bios-dump.bin" find attached), is of version 307.
                          My attempt to extract "GX701LXS-AS.311" using the "AMI_BIOS_GUARD_Extractor" was aimed at combining...
                          Badcaps - Capacitor Search Engine & Electronics Repair Forum
                          12-11-2023, 06:12 PM
                        • TOMÁŠ
                          Asus vivobook k513e bios request
                          by TOMÁŠ
                          Device:laptop
                          Brand: asus
                          Model: vivobook k513e
                          Motherboard: x513ea
                          SN: M5N0CV20H570216
                          Hi, I have problem with asus vivobook k513e. Came to with no pictures I found dump and flashed in to it, was working but did not see in bios ssd, so found another bios file now I can see ssd but laptop lagging evenin bios, also i opened hex editor and change serial number, maybe i did something?
                          sometimes not usable so i think its need beter bios, maybe fixing original or brand new but i don't know how to make it. Please can someone help me with this. Thanks for your help...
                          11-14-2024, 05:49 PM
