No power Hp 15-cc523ca MB DAG71MB16D0 Rev D
  • mferna14
    • Jun 2018
    • 1018
    Hi All, I am working on this Hp 15-cc523ca MB DAG71MB16D0 Rev D. The problem was that it was dead & the 5V IC SY8288CRAC was burnt & shorted the 19v rail. I replaced it, now no short at all & the 19v rail is fine on all points, but still it does not turn on. I get 3.3v on the power ON/OFF button connector & now assuming it might be a corrupted BIOS. Can anybody re-build this original BIOS. Thanks in advance
    • 20815
    Re: No power Hp 15-cc523ca MB DAG71MB16D0 Rev D
    See this thread https://www.badcaps.net/forum/showthread.php?t=103498 .Look at post #3
    Download your bios https://ftp.hp.com/pub/softpaq/sp134...0/sp134416.exe .Just follow the same steps in that post ,the only difference is the end offset
    220000 - 22803F (Length 8040)
    You can flash the virgin bios but you will lose all DMI info.You can copy the DMI easily with a hex editor and insert it into the virgin bios in less than a minute.The alternative is to use HP DMI tools.
    • mferna14
      • Jun 2018
      • 1018
      SMDFlea., soooo informative.. Thanks for taking the time & explaining how the BIOS bin is re-done. I will surely do it & inform you the out come.
      • mferna14
        • Jun 2018
        • 1018
        SMDFlea, Ok I think I have made the changes correctly, can you please verify whether I have done it the correct way. I have uploaded the Original BIOS & the Hp downloaded BIOS (Changes done).. My Hp uses ths 0836B BIOS Version. Thanks in Advance
          • 20815
          No its not right your bios version is BID08361 .Your DMI offsets are 220000 - 22803F (Length 8040) .Download your bios,run the exe to extract them https://ftp.hp.com/pub/softpaq/sp134...0/sp134416.exe open your backup and the extracted 08361 with hxd they will be side by side,enter the offsets in both, copy from your backup,paste insert into the 08361
          • mferna14
            • Jun 2018
            • 1018
            Thank you very much... I did it now, but still motherboard is missing 3.3/5V, I have no reason why., I will open a new Trouble shooting string... Thanks
            • mferna14
              • Jun 2018
              • 1018
              SMDFlea, Now please check whether I have done it correctly, first time doing it, so I am bit protective with the changes... Thanks in advance
                • 20815
                Perfect
                You can do any HP Insyde bios the same way (usually) you just have to find the offsets as they can be in different places.The win key offsets can be added seperately it doesn`t have to be,and isn`t always in one big block
                • mferna14
                  • Jun 2018
                  • 1018
                  Thank you so much SMDFlea, you taught us all.
                  • iulik17d
                    Intel Arc A380 videocard power limit remove - BIOS needed
                    by iulik17d
                    Hello everyone!
                    The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                    The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                    01-10-2025, 02:33 PM
                  • Victor Moreira Silva
                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                    by Victor Moreira Silva
                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                    Well, my decice specs are the following:
                    Model: Acer Nitro 5 AN517-54-55T5
                    CPU: Intel Core i5-11400H
                    GPU: NVIDIA GeForce GTX 1650
                    Motherboard: GH51G LA-L181P Rev:1c
                    The symptom:
                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                    05-26-2025, 10:49 AM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
