HP x360 14m-ba013dx bios bin
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi gooday i have a HP x360 14m-ba013dx and the board number is 16872-1 448.0C204.0011 i have provided an original backup below. I get no display with high fan speed after a few seconds.Hoping it's a bios issue. thanks for your help.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12281
    Re: HP x360 14m-ba013dx bios bin
    Old bios cleared ME.
    Bios download from HP home page :
      • 21692
      Go to the HP support site and enter the serial number on the case to search for driver and bios updates.Download the bios update executable - https://ftp.hp.com/pub/softpaq/sp133...0/sp133137.exe .Run sp133137.exe ,you`ll see a quick message about extracting an "insyde" bios. If you get a warning message about installing an insyde driver you can choose not to install it,it will pop up about 3 times.After the final warning a screen pops up with 3 options.Update,Make a recovery USB or copy. Choose the copy option and select a folder to save to. The bios is extracted to the folder you chose,there are 2 different ones,as the updater supports more than one machine.Open your bios backup with a Hex Editor and use the text search function to look for 083 ,you will see bios you need is 0830F .Next look for the laptop model number, the DMI (serial number,feature byte,win key) is all in one block.Open the 0830F virgin bios and scroll down to 220000 you will see that area starts with 00`s (not FF`s) ,go back to your backup and select the offsets in the picture, copy and paste insert into the virgin bios using the same offsets and save.
      • platinumsteel
        • May 2019
        • 234
        • Trinidad&Tobago
        Thanks a lot SMDFlea for teaching me how to fish.lol I did exactly as you mentioned and was able to use the Bios from HP Website and also add in my offsets and stuff..The bios is 100% working.Only thing it seems like i had another issue.I will only get it to boot up to bios if i apply some heat around the BIOS and KBC area. under the bios on other side of board is the memory controller. So i'll post in other section My issue.But hoaca388 thx for the clean Me Region clean.I assume it will be working as well.
        • johansel
          • Feb 2022
          • 39
          • colombia
          good afternoon friend SMDFlea excellent contribution you have taught me something valuable, a query that way of cleaning ME is the same for other bios that is to say other brands of laptop? or only apply for HP
          Thanks in advance
          • Jse Enrique
            • Feb 2021
            • 38
            • cuba
            thanks bro for the stuff
            • kenkaniff
              HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
              by kenkaniff
              Product Name: HP Pro x360 Fortis 11-inch G9
              System BIOS: U94 Ver.01.08.00 10/06/2023
              Serial Number: 5CG31946F5
              SKU Number: 85W05EC#AK8
              Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
              This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
              I needed to remove bios password...
              10-01-2025, 04:32 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
