HP BIOS unlock tool
 Re: HP BIOS unlock tool
 Not always but in some cases, yes. Those sections have different lengths so I did not try to clear the whole section because in my case, I never needed to. But seems like there are bunch of laptops which have a bit different kind of passwords.Comment
 As you can see in my original bios file, zero-ing until AA55 is a large extension, but I'd like to give that a try.
 Is the AA55 itself also supposed to be zero'ed out? Or is AA55 the first non zero data?Comment
 AA55 must stay as it is. And zeroing is not exactly the right word. You need to copy clean UserCred section with the same length from another file. There are other values in that section which have to be present for it to work. That's the main reason I did not want to clear up to AA55 automatically.Comment
 I see. I did also buy a seperate bios chip online, pre-programmed without password.AA55 must stay as it is. And zeroing is not exactly the right word. You need to copy clean UserCred section with the same length from another file. There are other values in that section which have to be present for it to work. That's the main reason I did not want to clear up to AA55 automatically.
 But that file seems to be written in a new format or something, cause the UserCred is not found if I hex open the rom file.
 Only with UEFITool I can find the UserCred and AdminPW sections, so it seems they are packed in the original rom file.
 Here is the rom file from the seperate bios chip, clean. Maybe you can find anything in it?Attached FilesComment
 Hi i had a hp830 g5 with locked bios password
 i removed battery and did not use power adapter either I soldered direct onto the 256 bios chip using magnet wire USE mag glass to check for solder bridges on pins before proceeding and connected wires onto a set of pins that would fit into the ic socket on the ch341 programmer i had already done the 3V mod to the ch341 i kept the wires about 9 inches long and spaced them apart .. i ran the ch341 software and did 4 reads and compares and verify s to each saved file to make sure code was same and good i also looked through code to check it was good in particular around address 1b00c00 where USER CRED is i then used unlock program to change code ....then after checking it was changed and good i erased chip this did not work first time took 3 goes to get clear erased chip so this is a MUST do you must check its a clean erase before you proceed... DONT RELY ON THE PROGRAM IT SAYS erase DONE WHEN ITS NOT always perfect ...i even used AS Programmer software to erase then i programmed with new unlocked bin file and then read and verify and another read and verify and manually went and checked code again from bios chip all was ok removed wires reconnected battery and powered on this time i was able to get into bios ok no other problems at all reset bios password to 12345678 as easy to remember so proof the unlocker works with HP830 G5 ....if it fails then you didnt copy bin properly or you did not have a fully erased chip ...once it was half erased with some code still near end ...SO MAKE SURE IT IS BLANK before try to program ....with the slow read and program speed be patient and dont cut corners....steve pComment
 In the spirit of something you mentioned in OP re: any improvements.. how about a small feature of producing a log file which details the password that was set..? As example - I have 3 laptops and I suspect they are all set using same password.. Might be able to unlock the remaining ones old fashioned way.. Superb work though!!! - tool is very very useful post HP non SMC help.!!!!Comment
 Can't get that feature. Passwords are encrypted and I do not know how to decrypt them.Comment
 could someone please check this BIOS BIN files? I have unlocked with the tool but the laptop starts with no Video output and the fan runs with max speed.
 Laptop is the HP 830 G5 Model and the BIOS has the latest Version:01.11.01 Rev.A
 Thanks for your helpComment
 Every donation made will go towards server fees and maintenance costs.Comment
			by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
 Thanks-
							Channel: BIOS Requests ONLY!
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
 This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
 I have opened the laptop and identified the main BIOS chip...2 Photos-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
			by m1ch43lzmHi everyone
 I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
 Programmer models: XGecu TL866II Plus / T48 / T56 / T76
 Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
 There's also an extra OTP Secu.R...-
- Loading...
