HP BIOS unlock tool
  • MchRichelieu24
    • Jun 2025
    Could you unlock my BIOS?
    HP Zbook g5
    SN 5CD9131MFN
    • peste
      • 13357
      • ROMANIA
      #1602
      HP Zbook g5
      SN 5CD9131MFN
      post the original contents of the bios chip..
      The bios chip must be unsoldered from the board before writing or reading..
      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
      solder wires between the programmer and the bios chip..
      you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        #1603
        I have a strange behavior with unlocked 8440p.
        Admin password removed succesfully, i can enter bios with F10 BUT i can't change any setting, whatever i do when i save, exit and enter again BIOS it's not stored, like it's locked on specific settings.
        I tried factory defaults, secutiry reset, bios update through Windows but no success.
        Seems like the admin password really gone but the permission to make changes in BIOS remained.
        Attached is the unlocked file that i flashed.
        What do i miss?
        SN: CZC13O234X
        Thanks in advance!
        • hoaca388
          Badcaps
          • Jan 2022
          • 12249
          #1604
          What do i miss?
          SN: CZC13O234X
          Thanks in advance!
          Try clear ME .
          https://www.badcaps.net/forum/troubl...22#post1622422
          ​https://www.badcaps.net/donate
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            #1605
            Originally posted by hoaca388
            But it's the original BIOS from this particular machine, i didn't use from another laptop, still need ME cleaning?
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              #1606
              What do i miss?
              SN: CZC13O234X
              Thanks in advance!
              Can't make MEanalyzer to run, colorama, crccheck etc seems impossible for me to install. Can someone clean ME to try it please?
              Thank you!
              • akorede
                ENGINEER
                • Nov 2020
                • 16
                • nigeria
                #1607
                https://www.indiafix.in/2025/06/hp-g...wnload-hp.html
                might be usefull
                • Zadiq
                  • Mar 2020
                  • 7
                  • Nigeria
                  #1608
                  Will it work with 840 g5
                  • peste
                    • 13357
                    • ROMANIA
                    #1609
                    read post #1..
                    • soniqu
                      • Dec 2021
                      • 7
                      • Україна
                      #1610
                      hi, problem with BIOS Probook HP 450 G6, black screen, need help, SN: 5CD9369GNG
                      • Sidqi Januar Riadi
                        • Dec 2024
                        • 15
                        • INDONESIA
                        #1611
                        Originally posted by RethoricalCheese
                        First check this site to see if your HP is supported for the great tool Mazzif has made.
                        http://mazzifsoftware.blogspot.com/p...os-unlock.html
                        If your model is newer and not in that list, you need to dump your bios, remove password from dump and reprogram bios with modified dump.
                        For that you need an SPI programmer like CH341A or Raspberry Pi with Flashrom or any other similar programmer. A soic8 clip is also useful so there wouldn't be a need to unsolder bios IC.
                        When you have your dump, just drag and drop your file on my HPUnlocker tool and it will create a new file. It will add "_unlocked" to the name of your locked file.
                        Just program the new file on your bios IC.
                        This unlocker should work on all Elite, EliteBook, ProBook and maybe some other series HP laptops.
                        For those of you who need to unlock large amounts of laptops, I recommend adding a registry entry:
                        Code:
                        Computer\HKEY_CLASSES_ROOT\*\shell\HPUnlocker\command
                        Then modify that string adding
                        Code:
                        "C:\*location-of-exe*\HPUnlocker.exe" "%1"
                        This way you just need to right click your locked file and select HPUnlocker.
                        If there are any issues, please do let me know so I can improve this tool.
                        All Elitebooks, Probooks and zbooks which are up to ninth generation which should be up to year 2018, like 840 G5, are supported. Newer models are not supported (yet atleast).
                        No Pavilions or other trash is supported
                        NEW multitool and unlocker added .
                        Unlocking
                        HP - ProBook, EliteBook, ZBook (including 32MB models)
                        Chromebooks from all various manufacturers
                        Apple - everything older than T2
                        More to come...
                        RCUnlocker https://www.badcaps.net/forum/showthread.php?t=98539
                        thanks so much brorther ,god bless you
                        • tax1969
                          • Dec 2015
                          • Ukraine
                          #1612
                          HELP please remove pass from my HP EliteBook 820 G4!
                            • 21620
                            Post the laptop serial number. Did you try the unlocker at post #1 ?
                            • tax1969
                              • Dec 2015
                              • Ukraine
                              #1614
                              Thanks bro, try now
                              • tax1969
                                • Dec 2015
                                • Ukraine
                                #1615
                                I do it, a lot of thanks to SMDFlea!
                                  SMDFlea commented
                                  Editing a comment
                                  Thanks to RethoricalCheese too for the great software
                              • salim5566
                                loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                by salim5566
                                Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                06-26-2025, 03:25 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • Citymin
                                by Citymin
                                S/N : 5RNK9FFT70...
                                08-05-2025, 05:12 AM
                              • m1ch43lzm
                                by m1ch43lzm
                                Hi everyone
                                09-06-2025, 05:47 PM
                              • Forest79
                                by Forest79
                                07-23-2023, 07:39 AM
