HP BIOS unlock tool
  • Jesse James
    • Sep 2018
    • 95
    Funny thing before I zip the file they are both 16.0 MB (16,777,216 bytes)
    Why would this be?
    I've read alot on this forum today and not sure to install a new bios and then try to go trough the process of installing all bios information. Not sure its a little more than I can understand at this point.
    • hoaca388
      Badcaps
      • Jan 2022
      • 12249
      #1542
      Why would this be?
      Because it contains mostly FF characters.
      • Jesse James
        • Sep 2018
        • 95
        Thank You for the help
        So my orig bios was verified and still bad.
        Any suggestions on where to go from here?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12249
          #1544
          Now you have to restore bios and ec by getting the files in this topic,
          https://www.badcaps.net/forum/troubl...itebook-840-g2
          • Jesse James
            • Sep 2018
            • 95
            Hello all. I followed the link as best I could. Flashed the bios again. Laptop is fully functional but very slow startup and HP logo sign. I am not sure what file to use if EC needs to be repaired. All laptop info looks correct in bios. I assume that is ME area? I'm confused as this is a bin right from here and every comment says no issues
            Any help would be great.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12249
              #1546
              Upload main bios.
              • Jesse James
                • Sep 2018
                • 95
                This is what I used from post 19
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12249
                  #1548
                  HP EliteBook 840 G2 Base Model Notebook PC
                  • Jesse James
                    • Sep 2018
                    • 95
                    Thank You hoaca388 ​ for all the help. It worked great. Laptop is all working. I've lost some bios information but I will search out the HP tools on this site to help input some of the lost info. I know I came across a bunch of info.
                    • slaweks
                      • Aug 2018
                      • Poland
                      #1550
                      Thank You ))))
                      • Yassoun75
                        • Sep 2017
                        • 15
                        • France
                        #1551
                        Hello, I need to remove the password on a Elitebook 840 G5.
                        RC unlocker did not work because it is a 32MB EEPROM...
                        Prod ID 2FA66AV
                        SN 5CG9236L4L
                        motherboard C0796B10WEA rev1.11 (Full Intel, no dedicaced GPU)
                        ThanX!​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12249
                          #1552
                          Prod ID 2FA66AV
                          SN 5CG9236L4L
                          ThanX!​
                          HP EliteBook 840 G5
                          Serial_5CG9236L4L
                          Product_2FA66AV
                          Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkjh.F5
                          Build Id_17WWCSCT601#SABF#DABF
                          • Yassoun75
                            • Sep 2017
                            • 15
                            • France
                            #1553
                            Originally posted by hoaca388
                            HP EliteBook 840 G5
                            Serial_5CG9236L4L
                            Product_2FA66AV
                            yhank you for your help but I have a problem.
                            the keyboard is out of order (I did not know that "detail") so I did desold and resold twice but at the second time, I swipe one or two components (I'm sure for one, this circle alone, next the white arrow).
                            I think it was resistors.
                            Do you have the resistance of them?
                            EDIT> I found what I need on the forum :-)
                            Very nice forum here!
                            • qayyum786
                              • Aug 2018
                              • 1958
                              • INDIA
                              #1554
                              Use 4.7K ohm
                              • Hiva Amiri
                                • Dec 2024
                                Hi
                                I have an HP 8470p with W25Q128BVFG bios chip. Is there a way to reset the password without dumping the chip using a programmer?
                                Also all the instructions are for the 8 pins chips. This 16 pins chip is a bit different. Would you please help me here? thank you
                                  • 21620
                                  Originally posted by Hiva Amiri
                                  Hi
                                  No.
                                  You can buy a SOP16 clip to go with your programmer, or if you have the tools to desolder the chip get a SOP16 test socket or adapter board
                                  • chelsea1155
                                    • Dec 2014
                                    • 32
                                    • vietnam
                                    #1557
                                    Hello. i need unlock bios for HP 850 g8.
                                    SN# 5CG1351RTT
                                    • shiyab
                                      • Sep 2023
                                      • 1592
                                      • india
                                      #1558
                                      SN# 5CG1351RTT
                                      post both file
                                      • soniqu
                                        • Dec 2021
                                        • 7
                                        • Україна
                                        #1559
                                        Hello. i need unlock bios for HP 840 g5.
                                        SN# 5CG9032WDB​
                                        • shiyab
                                          • Sep 2023
                                          • 1592
                                          • india
                                          #1560
                                          SN# 5CG9032WDB​
                                          hi try flash ec file
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
