HP BIOS unlock tool
Re: HP BIOS unlock tool
Hi
need help ,
My hP omen laptop ax236tx model has stopped working . No display only capslock blinking 5 long 3 short. I have checked ram and reset cmos and did every thing which links with this code, flashed bios chip using soic8 clip adapter and SPI programmer using help from this forum.
Can someone check my bios file what is wrong with this file, do it needed to unclock or not. i retrieved this file from my laptop bios chip Gigadevice GD25B64CS1G
thanks for help. I am stuckLast edited by SMDFlea; 10-03-2020, 09:34 AM.Comment
Didn`t you read post #442Hi
need help ,
.Your bios has been deleted,you`ve already posted it in another thread.
Sorry , It will never happen again But my concern was does my laptop model will get benefit from HP bios unlocker or no need of it
please help me to solve this OMEN laptop no display issue.Comment
The HP BIOS unlock tool is a bios password unlocker,it will only remove bios passwords for certain HP models,not pavilions,not omen models either.This tool will not help with a black screen issue.Comment
Thank YOU Understood.
Please help to check file i posted in another thread.Comment
Thanks. Since the model was released around the same time as laptops with 8000U CPU's I guess there's hope at least.
Is Sure Start a problem for using the method in the OP? Generally speaking.Comment
Haven't had an issue with surestart yet.
You should factory reset settings and security settings after restart. This should make it like it was never locked before.Comment
that's 2 file bios i found in motherboard
plz help...Attached Filesif you find these attachements useful please consider making a small donation to the site
try this if it works enter the DMI informationAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
i tried 2 file but it's not working , then i kept file 32M orig + file 16M (you fixed) -> it's work -> bios password removed
But have a problem -> security device
you have any solution , thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
try again with what I sent you to post # 454, the 33mb bios posted by you is longer, it can't work ... and be careful when writing ...Last edited by peste; 10-07-2020, 06:09 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi 8470p (3rd gen) issues. Winbond 25Q128 16legs chip.
When i use tool and put new dump i have black screen, no power at all.
Rollback and working fine so dump is ok. Any ideas? Ive got only problem on two this models.Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
