HP BIOS unlock tool
  • onizzbox
    Banned
    • Nov 2018
    • 604
    • Brazil
    #1241
    Re: HP BIOS unlock tool
    Originally posted by alimcorp
    I've done everything. And why is the red line "system is booting in manufacturing program mode" now shown at the top? What does this mean?
    @alimcorp
    Some MPM data is missing, check 1/7
    MPM Product information:
    1. Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPhKhkjhk8.gn
    2. Build Id: 19WWTLCT601#SACB#DACB
    3. Serial Number: 5CG0257WZB
    4. SKU Number: 8ML12ES#ACB
    5. Product Family: 103C_5336AN HP EliteBook
    6. SB CT Number: PJBVR00WBDV60B
    7. Product Name: HP EliteBook 745 G6
    • alimcorp
      • Feb 2021
      • 23
      • Moldova
      #1242
      Originally posted by onizzbox
      @alimcorp
      Everything is checked in detail down to each character. There are no errors.
      • alimcorp
        • Feb 2021
        • 23
        • Moldova
        #1243
        There were 20 reboot attempts. Each time, the number decreased by 1. After 20 reboots, the inscription no longer appears, but the PASSWORD again appeared to enter the BIOS.
        • onizzbox
          Banned
          • Nov 2018
          • 604
          • Brazil
          #1244
          @alimcorp
          Now I understand, it is necessary after unlocking, on first boot, BIOS needs to be reset to factory default. Only after entering the MPM data.
          For this you will need to program the BIOS again.
          • alimcorp
            • Feb 2021
            • 23
            • Moldova
            #1245
            Let's agree on the exact sequence of actions.
            1. I solder and reflash U365 again.
            2. I turn on the laptop, go into the BIOS and install MPM. I save and reboot.
            3. I go into the BIOS and reset the settings to factory settings. I save and reboot.
            So to do?
            Or swap steps 2 and 3?
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #1246
              1, 3, 2
              • alimcorp
                • Feb 2021
                • 23
                • Moldova
                #1247
                @alimcorp
                No, it doesn't work. After flashing, I immediately reset the settings to factory settings. After the reboot, I entered the MPM data. Still the red inscription comes out. If I reset the settings again, the MPM information disappears, and the number on the red inscription again goes from 33 downwards.
                He does not like the MPM information, although I enter everything correctly, I tried it several times and double-checked it several times.
                • alimcorp
                  • Feb 2021
                  • 23
                  • Moldova
                  #1248
                  @alimcorp
                  I found a solution to the problem.
                  While the BIOS lets us in and allows us to change the administrator password, I set my password. Then he rebooted 33 times until the red inscription disappeared. After that, the BIOS asked for a password to enter, and my password worked!
                  • onizzbox
                    Banned
                    • Nov 2018
                    • 604
                    • Brazil
                    #1249
                    @alimcorp
                    It's not necessary... But that's ok!
                    The important thing is that you got it resolved.
                    • alimcorp
                      • Feb 2021
                      • 23
                      • Moldova
                      #1250
                      @alimcorp
                      Thank you for your work. We are waiting for your tool to publish))
                      • Jesperb
                        • Jul 2016
                        • 6
                        • Denmark
                        #1251
                        Hi All, i'm getting this error message.. "HP Endpoint Security Controller Problem
                        There is a problem with the HP Endpoint Security Controller on the unit
                        Please contact HP Inc. to have the unit serviced ".. after trying to program HP 850 G6 bios chip. Could someone help me remove it (by new bin file), that actually works?? :-)
                        Have attached my original bios file :-)
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12322
                          #1252
                          New file
                          ​https://www.badcaps.net/donate
                          • Jesperb
                            • Jul 2016
                            • 6
                            • Denmark
                            #1253
                            Originally posted by hoaca388
                            New file
                            Thanks hoaca388, the file you posted is exactly the same as the file i have written to the bios already. Did you alter any code in the file ? OR did you just unlock it with HP-Unlocker tool ?....Because it is identical to the file that's currently in the BIOS chip, see picture
                            Br
                            jesper
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12322
                              #1254
                              No, i was build a new file from your file. Of course it should be 16MB.
                              • Jesperb
                                • Jul 2016
                                • 6
                                • Denmark
                                #1255
                                OK, i will flash your file, see if it solves the problem
                                • kba81
                                  • Mar 2022
                                  • 8
                                  Does HP Unlocker work with HP 830 G5 from 2018 with chip W25Q256JVEQ?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12322
                                    #1257
                                    Unlucky, it not work with 32MB bios.
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #1258
                                      Read first post. It links to rcunlocker, use that.
                                      • kba81
                                        • Mar 2022
                                        • 8
                                        Thank you guys for your advice.I really appreciate that.
                                        Do I have to remove the chip from motherboard or I can use clip attachement with EZP2019 programmer?
                                        • Jesperb
                                          • Jul 2016
                                          • 6
                                          • Denmark
                                          #1260
                                          I never got it to work with the clip, so my advice is to remove the chip.
                                          Did you check the chip on the upper side towards the keyboard, or is that the chip you are referring to here ?
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
