HP BIOS unlock tool
Upload main bios.Hello all. I followed the link as best I could. Flashed the bios again. Laptop is fully functional but very slow startup and HP logo sign. I am not sure what file to use if EC needs to be repaired. All laptop info looks correct in bios. I assume that is ME area? I'm confused as this is a bin right from here and every comment says no issues
Any help would be great.Leave a comment:
Now you have to restore bios and ec by getting the files in this topic,
https://www.badcaps.net/forum/troubl...itebook-840-g2Leave a comment:
Thank You for the help
So my orig bios was verified and still bad.
Any suggestions on where to go from here?Leave a comment:
Because it contains mostly FF characters.Funny thing before I zip the file they are both 16.0 MB (16,777,216 bytes)
Why would this be?
I've read alot on this forum today and not sure to install a new bios and then try to go trough the process of installing all bios information. Not sure its a little more than I can understand at this point.Leave a comment:
Why would this be?
You're in trouble because your backup fault.Hey guys. Need help. So I used HpUnlocker on my functional 840 G2 laptop. I saved the orig dump. Ran it through the program and flashed it back with verify. Now laptop has black screen and caps light flashing. Tried multiple times. Then I downloaded HP bios from site and installed through holding "B" and it fixed it BUT now it says
Custom logo image greater than 1024x760
Warning Machine is not in committed state
Good news is there is no password
I have attached both
I'm at a loss and hopefully someone can help
FYI other than probably my mistakes this tool is Amazing
I seem to be posting in the wrong places lately so I hope as this has everything to do with HpUnlocker it's right.
HP EliteBook 840 G2
Ser # 5CG609237S
System Board ID 2216
MB info N/A at this timeLeave a comment:
I seem to be posting in the wrong places lately so I hope as this has everything to do with HpUnlocker it's rightLeave a comment:
read..https://www.badcaps.net/forum/troubl...before-posting
Post the full name and model of the laptop, S/N, etc... -
I tried to remove password protection from the various info, but was not able too.
Attached FilesLeave a comment:
I would like to thank you for this program. It works and helped me with unlocking BIOS.Leave a comment:
Hi there!
I have a hp elitebook 745 g4 and need the bios password removed can you help me?
Which chip do I need to reprogram U366 or U365?Leave a comment:
flash bothAttached FilesLeave a comment:
Today I have already unlocked several laptops of this model, but the problem is only with this one. Previously, I left the BIOS file from the ISSI chip, add one from Winbond 256 to the archive. I've already tried everything I can.
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
- Loading...
