HP BIOS unlock tool
  • corona100
    • Mar 2020
    • 155
    • U.S.A
    #1101
    Re: HP BIOS unlock tool
    Hp 830 G5 not working with RCUnlocker due seize problem but it's working well with HPUnlocker
    • mixsa
      • Oct 2021
      • 5
      • Sweden
      #1102
      Hi! Need help, I have an Elitebook 1040 G3. Unsoldered the BIOS-chip (W25Q64FV), attached it to CH341, did 3 dumps that were zero differences, continued to RCunlocker, did not work ("Missing unlockable content", the HPunlocker did produce a "_unlocked" file, erased the W25Q64FV and flashed "_unlocked".
      However, now when i read the chip again and compare it to the unlocked version, I get 1500 differences? And I also get "Verification error on address: 0000000F" in AsProgrammer 2.0.2. Don't know what to do!!!
      Can someone have a look at my files and see if something is off? thanks!
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #1103
        That error message was a huge hint to you. You are trying to modify the wrong chip...
        • sidji
          • Oct 2021
          • france
          #1104
          Hello RethoricalCheese! Thanks for your great tool! It might help me accessing my HP Revolve810 bios again! As a big idiot I did not write down my pwd so I can't access Bios setup anymore ;-( If I understand well, I need a file to use your HPunlocker.exe
          The trouble is I don't know where to get that file ;-( Do I need to unsolder the BIOS chip first???
          Thanks for your help and understanding!
          Cy
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #1105
            From your bios chip. You need a programmer for that.
            • miraya
              • Mar 2020
              • Iraq
              #1106
              Can anybody help me out here? I m trying to unlock an HP 820 G3, tried for several days no luck so far, I have tried different programmers, whenever I flash the original BIOS file the system boots up but the password is still there, when I flash the unlocked bin file, it either wont respond or will flash yellow and orange indicators then go full fan spin, I also tried to recovery bios by USB with official HP rescue tool, no luck either. I will attach both original bin and modified bin below, could anyone knowledgeable take a look please and guide me in the correct direction, I have an CH341a black minprogrammer, I mainly use NeoProgrammer, seems to be most stable among the bunch I tried.
              Someone guide me in the right direction.
              • peste
                • 13880
                • ROMANIA
                #1107
                try..
                • rudelito
                  • Jun 2019
                  • 14
                  • Phillipines
                  #1108
                  my hp 840 g6 was unlocked in bios password i flash it in 16mb
                  but in past few days but it happens in detect in swat always i dont what it means but the bios ok i hope someone can help ehis issue
                  • miraya
                    • Mar 2020
                    • Iraq
                    #1109
                    thanks, I finally solved it. I used RCUnlocker, erased the EEPROM wrote the file then verifiedit, at first I thought nothinf had changed. I did a few power cycles, inserted a USB with rescue BIOS first it didnt work then I put it in a different port while powercycling, now iy works perfectly fine, thanks for the help.
                    • andrukis
                      • Nov 2015
                      • Ua
                      #1110
                      hi i need unlock BIOS Adminitrator Pass. ZBOOK studio G7, LA-j242P.
                      you can help me?
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        #1111
                        you can help me?
                        Upload your 16MB dump here. You can use RCUnlocker:
                        https://www.badcaps.net/forum/showthread.php?t=98539
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • andrukis
                          • Nov 2015
                          • Ua
                          #1112
                          Thank you !!!!
                          all worked!!!
                          • ssh
                            • Sep 2021
                            #1113
                            Re: HP BIOS unlock tool for ZBook G3
                            Originally posted by ssh
                            Hello guys!
                            I have a ZBook 17 G3 laptop with Power-On password set - password that I don't know for I've never used it (nor set it explicitly). I've been using my unit for years now, unlocking it with my fingerprint, until new fingerprint driver reinitialized something and removed my fingerprint (and left me with a power-on password I never used nor intended to - HP Client Security tool I used to register my fingerprint for power-on auth also associated windows password with it).
                            I know main BIOS (admin) password, but it's of no use for I can't get into BIOS...
                            Anyway, my unit has Winbond 25Q128FVSQ chip, mentioned on a few pages in this thread:
                            1. This one shows use case I could use (before unfortunate fingerprint removal, there was Bios Administrator user option on power-on authentication screen)
                            2. This one is for very similar laptop, though I don't know what was the problem with it...
                            Before I try it out, I'd rather ask first, could this unlocker tool help me with the problem I have? These two posts made me think so, but I'd better play it safe... I don't expect any guarantees (would be silly to do so), rather an advice or a guide. Thank you!
                            Just got CH341 thingy with the clip (8 pin), disconnected main and CMOS batteries, made sure I properly connected everything and tried to read the chip, but without success. Managed to make it worse then it was - now I get 5 led blinks on boot... Any clues - messed up bios chip or the motherboard? Thanks
                            • rbnote
                              • Nov 2013
                              • 83
                              • brazil
                              #1114
                              Hello guys I need a help with pass 840 g7, rcunlocker no work
                              • black0hackers
                                • Jul 2020
                                • 369
                                upload 128mb bios
                                • Mrs.c0deina
                                  • Oct 2021
                                  • RD
                                  #1116
                                  Good I really need help, I have read hundreds of messages but I really do not understand how HPunlocker works if there is a guide could you pass it to me or tell me the steps to follow. to unblock the bios
                                  pd: I have an elitebook 840 g3 with bios locked by password and I need to access it to activate virtualization and be able to do my homework.
                                  Thank you
                                  • peste
                                    • 13880
                                    • ROMANIA
                                    #1117
                                    Thank you
                                    read post # 1
                                    • slaby.uczen
                                      • Nov 2021
                                      • Poland
                                      #1118
                                      Works well. Thank you!
                                      • bp1
                                        • Jul 2010
                                        • 46
                                        #1119
                                        Big thanks to everyone here for their great posts.
                                        I have a HP640g1 which was bios locked with a forgotten password from a couple of years ago. Followed the instruction from post 1. All good now.
                                        Did run into a few problems but that was user error (Myself).
                                        Laptop now with unlocked bios.
                                        I have now experimented with both unsoldering the bios chip and using the SOIC clip method.
                                        My problems encounted was poor resoldering of the chip back which looked good under a magnifying glass but was bad as all i got was a black screen, power button permantly lit and flashing yellow charging light. After removal and resoldering this problem was resolved and i could see pin 8 bent previously not making a good contact.
                                        The clip method also works but i had to ensure good contact was maintained during write as advised in other posts by checking and verifying the bios.
                                        • ScootBrown
                                          • Nov 2021
                                          Looking for help removing the BIOS password on a HP Elitebook 830 g7. If someone can please look at my BIOS file and let me know. Thanks.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
