HP BIOS unlock tool
 Become a Badcaps supporter
 Thanks to all supporters.​
 ----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..
 Re: HP BIOS unlock tool
 Fair play, I thought that, but .....you know...I was hoping it wasn't fubar.
 I've been playing with the Ch431 on scrap chips, just reading them and stuff (getting better with the clip), also started using NeoProgrammer instead of the included one.
 Checked my pins and they all seem to be 3.3v so I don't need the 5v hack.
 Next question, does anyone have an 840 G2 BIOS I can try an flash? Failing that I am going to have to de solder aren't I? Then either flash an image or buy a new 25Q128A?
 Cheers,
 DComment
 Sorry to bother but I have 2 more dumps from an HP 830 G7 that have a bios password and was looking for some help. Thanks.Attached FilesComment
 Try & leave feedback:----------------------------------------------------------------------------------------------------------------------------------------------------------
 ----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
 I ask the Great Nobles for help.
 I can not reset the password for the HP645 G4 BIOS. I tried using this utility. The chip is sewn, but when turned on, the password for entering the BIOS pops up all the same.
 Maybe someone can overwrite this password?
 Bios attached below.
 THANKSAttached FilesComment
 Sorry to bother but I have 1 more dumps from an hp probook 450 g7 that have a bios password and was looking for some help. Thanks.Attached FilesComment
 sorry But I have a question
 can we make a bios dump that just make some line clear and the other line remains untouched
 for removing password when we have at least 100 pcs from one model with bios lock problemsComment
 You can use flashrom and tell it to only read/write a small section. That's what I do to unlock HPs in just a few seconds  Comment
 Read the manual, it's easy enough to understand. But it is only useful if you have to unlock tens or hundreds of same models like you have.Comment
 I would like to have an answer for some little details before flashing a bios.
 First of all I read all 53 page of this thread but didn't find my answer.
 I would like to know if the bios provided by hp in their bios update package are an entire bios ? which would be superb for my need.
 Second, does your unlocker @RethricalCheese work for a HP Z440 ?
 I looked and it has a W25Q128FVSQ chip which retain the bios password even after a cmos reset, but luckily no trace of a second chip.
 I will be using a CH431a with neoprogrammer ( it seems like the most appreciated here ) like everybody but I will be stuck with the clip as by budget cost I can't afford a desoldering tool.
 Thanks  Comment
 For Intel boards, it does not contain whole content.
 On your machine, look for green jumper, remove it, turn on your PC and enter bios. After that turn it off and put back the jumper.Comment
 Thanks for the fast reply,
 Unfortunately the green jumper only remove the power-on and startup password not the admin password
 I also tried the boot block recovery but it failed to change the bios ( might be because it's not the entire bios as you said )
 If I have to use your unlocker do you think it will work ?
 The HP Z440 is a machine from 2015 but being a workstation and not a laptop, I would like your confirmation.Comment
 Hi, i'm back with some news
 First my ch341a will arrive in late afternoon in my country ( currently 11am )
 Second, @RethoricalCheese, your jumper may remove the admin password BUT I dumped the bios config via the hp bios config utility and found that this jumper can be disabled
 Here it is in attached files ( I deliberatly deleted some informations specific to my pc )
 Now that my only way to remove it is by your unlocker, do you think it will work ?
 Again, the boot block recovery procedure doesn't work
 Thanks in advanceAttached FilesComment
 Yeah, well, I don't know. Since the hundreds or thousands of desktops I've unlocked all have been using jumper, I have not taken a look inside the bios yet.
 Just read your bios, make a topic, upload it there and we shall see what we can do.Comment
			by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
 Thanks-
							Channel: BIOS Requests ONLY!
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I have opened the laptop and identified the main BIOS chip...2 Photos-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
			by m1ch43lzmHi everyone
 There's also an extra OTP Secu.R...-
- Loading...
