HP BIOS unlock tool
  • black0hackers
    • Jul 2020
    • 367
    Re: HP BIOS unlock tool
    Originally posted by RethoricalCheese
    This method is not okay... You should warn people that MPM will be unlocked and all DMI must be reinserted again.
    Try this instead - you just need to reset security settings to default after you get into bios.
    where is offset to fix sir?
    • dj831
      • Jun 2015
      • 5
      • France
      #562
      Hi everyone, quick question: I'd like to avoid to desolder chip, since laptop si still under warranty for 6 months. For that, I'd like to dump EPROM with a clip (may not work, of course, since chip is still soldered).
      First, did you have success with an in-circuit reading? Second, do you know where I can purchase a clip, but not an SO type, but a QFN type? (QFN-8)?
      Thanks !
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #563
        There is none to tell. Point me to your file, I'll do it manually for now.
        • black0hackers
          • Jul 2020
          • 367
          Here is it Sir. Original Main and Ec bios file add below
          i has do it by myself: replace EC bios file (non pass) from another laptop, password is remove, but there are is problem when it turn on even when i clear ME Region Main bios.
          display showing
          "HP Endpoint Security Controller Problem
          There is a problem with the HP Endpoint Security Controller on the unit
          Please contact HP Inc. to have the unit serviced "
          Can you fix it to use for another Laptop bios password
          thanks you!
          • gastonxchile
            • Nov 2020
            • 9
            • Chile
            #565
            Hi to all, this works for HP Sure Start Password? Thanks
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #566
              display showing
              thanks you!
              First you would want to flash back both original files, just to see if that error disappears.
              let me know if it disappears, then I will try to patch correctly.
              • black0hackers
                • Jul 2020
                • 367
                it disappears sir. only aks for password
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #568
                  Try this and let me know if it works or has any issues. Flash only EC bios.
                  You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.
                  • black0hackers
                    • Jul 2020
                    • 367
                    it working, password is gone. now i test it on another laptop and let you know how it going! many thank you to Sir!
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #570
                      Nice. Do not use the same file on another laptop, you will brick it. Make copies of both chips, just in case and just send the EC file here. It's a bit tricky to get it correct.
                      • aldopc
                        • Jul 2017
                        • 465
                        • Chilito
                        #571
                        Hello friend I need your help please, I have this equipment with password
                        HP Elitebook 840R G4 I tried to clean the file with the tool that you published on the 32mb chip, but it did not work apparently the password is on the 16mb chip you. could you check it please.
                        • peste
                          • 13142
                          • ROMANIA
                          #572
                          if it works enter the DMI information ... proceed as in the video ..
                          https://www.youtube.com/watch?v=9T57ktw8n3Y
                          • aldopc
                            • Jul 2017
                            • 465
                            • Chilito
                            #573
                            Hello Plague Friend, I recorded both files that you gave me but there is no image, I have reloaded the original files and I have an image .... I appreciate your help, this model seems to be different in the forum there is nothing about this version (840R G4) Helpme please..
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              #574
                              Nah, this still needs main bios mod only. This should work fine and without needing any messing around with DMI.
                              • aldopc
                                • Jul 2017
                                • 465
                                • Chilito
                                #575
                                Excellent friend RethoricalCheese, it worked perfect, but tell me I did it with your v1 tool, and it didn't work, did you do it manually? or I did something wrong thank you very much master.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1519
                                  • Estonia
                                  #576
                                  I did it with my new and improved tool which I have not published yet (because automatic unlocks on newer models is a bit more tricky than it seems. Still needs more improving and testing).
                                  Old tool had a few bugs with certain bios dumps and your bios dump was an example of that.
                                  • aldopc
                                    • Jul 2017
                                    • 465
                                    • Chilito
                                    #577
                                    46 / 5000
                                    Resultados de traducción
                                    Ok, I'll keep an eye on the new version, thanks.
                                    • nguyendo_yen
                                      • Sep 2020
                                      • 14
                                      • viet nam
                                      #578
                                      Please unlock hp 430-g1
                                      • keczuk
                                        • 84
                                        • WWW
                                        #579
                                        Can you make patch (unlock) password for my HP 840 G5.
                                        This is EC file...
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #580
                                          This is EC file...
                                          Be sure to reset security settings to factory default.
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
                                          • Forest79
                                            by Forest79
                                            07-23-2023, 07:39 AM
