HP BIOS unlock tool
Re: HP BIOS unlock tool
Hi everyone, quick question: I'd like to avoid to desolder chip, since laptop si still under warranty for 6 months. For that, I'd like to dump EPROM with a clip (may not work, of course, since chip is still soldered).
First, did you have success with an in-circuit reading? Second, do you know where I can purchase a clip, but not an SO type, but a QFN type? (QFN-8)?
Thanks !Comment
Here is it Sir. Original Main and Ec bios file add below
i has do it by myself: replace EC bios file (non pass) from another laptop, password is remove, but there are is problem when it turn on even when i clear ME Region Main bios.
display showing
"HP Endpoint Security Controller Problem
There is a problem with the HP Endpoint Security Controller on the unit
Please contact HP Inc. to have the unit serviced "
Can you fix it to use for another Laptop bios password
thanks you!Attached Filesif you find these attachements useful please consider making a small donation to the site
display showing
thanks you!
First you would want to flash back both original files, just to see if that error disappears.
let me know if it disappears, then I will try to patch correctly.Comment
Try this and let me know if it works or has any issues. Flash only EC bios.
You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.Attached Filesif you find these attachements useful please consider making a small donation to the site
it working, password is gone. now i test it on another laptop and let you know how it going! many thank you to Sir!Try this and let me know if it works or has any issues. Flash only EC bios.
You will get an error first boot, just ignore it. Go to bios, reset security settings to factory default. If you can restart successfully without any errors then it works. Please let me know.Comment
Nice. Do not use the same file on another laptop, you will brick it. Make copies of both chips, just in case and just send the EC file here. It's a bit tricky to get it correct.Comment
Hello friend I need your help please, I have this equipment with password
HP Elitebook 840R G4 I tried to clean the file with the tool that you published on the 32mb chip, but it did not work apparently the password is on the 16mb chip you. could you check it please.Attached Filesif you find these attachements useful please consider making a small donation to the site
if it works enter the DMI information ... proceed as in the video ..
https://www.youtube.com/watch?v=9T57ktw8n3YAttached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Hello Plague Friend, I recorded both files that you gave me but there is no image, I have reloaded the original files and I have an image .... I appreciate your help, this model seems to be different in the forum there is nothing about this version (840R G4) Helpme please..if it works enter the DMI information ... proceed as in the video ..
https://www.youtube.com/watch?v=9T57ktw8n3YComment
Nah, this still needs main bios mod only. This should work fine and without needing any messing around with DMI.Attached Filesif you find these attachements useful please consider making a small donation to the site
Excellent friend RethoricalCheese, it worked perfect, but tell me I did it with your v1 tool, and it didn't work, did you do it manually? or I did something wrong thank you very much master.
I did it with my new and improved tool which I have not published yet (because automatic unlocks on newer models is a bit more tricky than it seems. Still needs more improving and testing).
Old tool had a few bugs with certain bios dumps and your bios dump was an example of that.Comment
46 / 5000
Resultados de traducción
Ok, I'll keep an eye on the new version, thanks.
Please unlock hp 430-g1Attached Filesif you find these attachements useful please consider making a small donation to the site
Can you make patch (unlock) password for my HP 840 G5.
This is EC file...Attached Filesif you find these attachements useful please consider making a small donation to the site
Be sure to reset security settings to factory default.Attached Filesif you find these attachements useful please consider making a small donation to the site
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
