HP BIOS unlock tool
  • Timbo01
    • Mar 2020
    • 7
    Re: HP BIOS unlock tool
    Originally posted by baselse
    Yes I did, but after going through the bios menu, there was a second prompt for the admin password which was not removed.
    See post.
    Did you just use the tool? or did you clear all hex values down to the bit that ends with hex AA55??
    • baselse
      • Jul 2020
      • 11
      • Netherlands
      #342
      I just used the tool.
      Is it better to clear further with hex edit?
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        #343
        Not always but in some cases, yes. Those sections have different lengths so I did not try to clear the whole section because in my case, I never needed to. But seems like there are bunch of laptops which have a bit different kind of passwords.
        • baselse
          • Jul 2020
          • 11
          • Netherlands
          #344
          As you can see in my original bios file, zero-ing until AA55 is a large extension, but I'd like to give that a try.
          Is the AA55 itself also supposed to be zero'ed out? Or is AA55 the first non zero data?
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #345
            AA55 must stay as it is. And zeroing is not exactly the right word. You need to copy clean UserCred section with the same length from another file. There are other values in that section which have to be present for it to work. That's the main reason I did not want to clear up to AA55 automatically.
            • baselse
              • Jul 2020
              • 11
              • Netherlands
              #346
              I see. I did also buy a seperate bios chip online, pre-programmed without password.
              But that file seems to be written in a new format or something, cause the UserCred is not found if I hex open the rom file.
              Only with UEFITool I can find the UserCred and AdminPW sections, so it seems they are packed in the original rom file.
              Here is the rom file from the seperate bios chip, clean. Maybe you can find anything in it?
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                #347
                For some reason, my uefitool does not want to open it.
                • baselse
                  • Jul 2020
                  • 11
                  • Netherlands
                  #348
                  It takes a minute on my pc too, but then it opens.
                  • IT-Guy
                    • Jun 2020
                    • 8
                    Nobody have an idea how to get rid of this?
                    I don't even know where to dig, google isn't really helpful
                    Any help is very apreciated
                    • keczuk
                      • 84
                      • WWW
                      #350
                      I need too solution of this problem ;(
                      • ste222
                        • Apr 2020
                        • uk
                        #351
                        Hi i had a hp830 g5 with locked bios password
                        i removed battery and did not use power adapter either I soldered direct onto the 256 bios chip using magnet wire USE mag glass to check for solder bridges on pins before proceeding and connected wires onto a set of pins that would fit into the ic socket on the ch341 programmer i had already done the 3V mod to the ch341 i kept the wires about 9 inches long and spaced them apart .. i ran the ch341 software and did 4 reads and compares and verify s to each saved file to make sure code was same and good i also looked through code to check it was good in particular around address 1b00c00 where USER CRED is i then used unlock program to change code ....then after checking it was changed and good i erased chip this did not work first time took 3 goes to get clear erased chip so this is a MUST do you must check its a clean erase before you proceed... DONT RELY ON THE PROGRAM IT SAYS erase DONE WHEN ITS NOT always perfect ...i even used AS Programmer software to erase then i programmed with new unlocked bin file and then read and verify and another read and verify and manually went and checked code again from bios chip all was ok removed wires reconnected battery and powered on this time i was able to get into bios ok no other problems at all reset bios password to 12345678 as easy to remember so proof the unlocker works with HP830 G5 ....if it fails then you didnt copy bin properly or you did not have a fully erased chip ...once it was half erased with some code still near end ...SO MAKE SURE IT IS BLANK before try to program ....with the slow read and program speed be patient and dont cut corners....steve p
                        • DeFacto
                          • Jul 2020
                          • Lietuva
                          #352
                          HP EliteBook 820 G2 confirmed. Thanks a lot bro
                          • willko
                            • Jan 2019
                            • 6
                            #353
                            Another success here. Thank You!!! HP 840 G2 locked BIOS - de-soldered MXIC SOIC 8 25L12873F package, read BIN with TL866II, applied unlocker, wrote back, re-soldered & booted to a unlocked BIOS. Wonderful!!!
                            • willko
                              • Jan 2019
                              • 6
                              #354
                              In the spirit of something you mentioned in OP re: any improvements.. how about a small feature of producing a log file which details the password that was set..? As example - I have 3 laptops and I suspect they are all set using same password.. Might be able to unlock the remaining ones old fashioned way.. Superb work though!!! - tool is very very useful post HP non SMC help.!!!!
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                #355
                                Can't get that feature. Passwords are encrypted and I do not know how to decrypt them.
                                • willko
                                  • Jan 2019
                                  • 6
                                  #356
                                  Ahh, of course - I suppose that is the whole point.. LOL - sorry me being stupid.
                                  Again though - thank you for this tool!!! Really helpful!!!!!!!
                                  • onelook
                                    • May 2020
                                    • 27
                                    could someone please check this BIOS BIN files? I have unlocked with the tool but the laptop starts with no Video output and the fan runs with max speed.
                                    Laptop is the HP 830 G5 Model and the BIOS has the latest Version:01.11.01 Rev.A
                                    Thanks for your help
                                    • peste
                                      • 13747
                                      • ROMANIA
                                      #358
                                      try..
                                      • shabi
                                        Banned
                                        • May 2019
                                        • 147
                                        • pakistan
                                        #359
                                        its a great tool plx working on Toshiba response code
                                        • Mozezz
                                          • Jun 2020
                                          • 17
                                          Hello my zbook 15 g6 bios is password protected. Ive bought a Ch341a Programmer with Clip. Which Chip I have to dump? The bios Chip? Thanks for any hint
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            by to5it0
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            Hi everyone
                                            09-06-2025, 05:47 PM
