Samsung NP900X4C-A01CA BIOS
  • mferna14
    • Jun 2018
    • 1050
    I am working on a Samsung Laptop NP900X4C-A01CA. The status right now is NO DISPLAY but the motherboard is drawing .75 milli amps (Amps fluctuates up & down a bit) & the CPU & the GPU even gets hot. VCORE voltages are all good & all all voltages seem to be good. Can anyone repair/fix this Original BIOS fo this laptop. Thanks in advance.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Samsung NP900X4C-A01CA BIOS
    try..
    • mferna14
      • Jun 2018
      • 1050
      Thank you peste, will surely try today & let you know... Take care, you are a real help!!!
      • mferna14
        • Jun 2018
        • 1050
        "peste"., Not working... I think there might be another problem with the motheboard. Same status as the previous original BIOS, motherboard just stuck on .75 milli amps.
          • 22293
          Originally posted by peste
          try..
          A lot of the older samsung bios get corrupted NVRAM . Try merging the bios update. https://www.badcaps.net/forum/showthread.php?t=88206 .The platform ID is ABK if its the original bios.
          Extract the DMI from the EVSA store using UEFITool (extract as is, just this EVSA store,not all of them) or with a hex editor 70AC00 - 70ADFF
          Samsung bios extractor attached.
          • mferna14
            • Jun 2018
            • 1050
            Thanks Peste & SMDFlea.. really appreciate!!! Going to do it for the first time.. Let's see how far I can go with this. So you mean I have to Extract the DMI from the EVSA Store & drag it to the Samsung Extractor with the Original BIOS Bin Files???
              • 22293
              No,the downloaded bios update needs extracting with the attached tool, then that extracted file wants copying/merging over the orig bios
              • mferna14
                • Jun 2018
                • 1050
                Thanks SMDFlea., 1st time doing this, so confusing. As I understand, 1st the original Samsung BIOS have to be extracted with the attached tool. & then extracted file need to be written onto a new BIOS chip. My apologies, did not get it, once I do it then it will be easier & even for everyone in this world. Thanks & thank you.
                  • 22293
                  The extracted file needs editing as it has a capsule header ,Select off-sets 0 - 1CF (length 1D0) ,delete.Then there`s more editing to do to make it the right size... its a 3MB update (bios region).
                  Try this bios .
                  • mferna14
                    • Jun 2018
                    • 1050
                    Thanks you so much SMDFlea., when I download this BIN file which you have send me, is it already edited as I see the properties of it, & it 8MB. So I believe you have send me the edit version file??? Right? or should I delete the off-sets 0 - 1CF (length 1D0) & then this will be the correct file to be programmed on the BIOS Chip? Thanks
                      • 22293
                      Its ready for programming.
                      • mferna14
                        • Jun 2018
                        • 1050
                        Thanks for the great explaination of how this Samsung BIOS is done & editing the BIOS for me.. Will Surely try it out today.
                        • Kambi13
                          • Aug 2022
                          • 134
                          • Portugal
                          Working Bios for a Samsung NP900X4C
                          Hello all, I need a Working Bios or a Dump Bios from a Working Samsung NP900X4C-A01PT
                          Best Regards
                            • 22293
                            Re: Working Bios for a Samsung NP900X4C
                            Best Regards
                            If you have a bios backup post it .
                            • Kambi13
                              • Aug 2022
                              • 134
                              • Portugal
                              Thank You SMFLea, I've tried to follow the post that helps with downloading the Bios but I only get a 404 error from the server.
                              Here's the dump file from this laptop
                              Bios version and Platform ID as follows P06AAC
                              Thank you in advance
                              • Kambi13
                                • Aug 2022
                                • 134
                                • Portugal
                                Ok, finally managed to get the Updated Bios from Samsung sever. Now I need some guidance to make this work
                                • hardware1
                                  • Sep 2021
                                  • 2949
                                  • N/A
                                  Here's your New BIOS, try it and let me know the results.
                                  all donations are welcome,
                                  • Kambi13
                                    • Aug 2022
                                    • 134
                                    • Portugal
                                    OMG Hardware1 it's working like a charm. Thank you so much. I was wondering if you could let me know what have you merged into the original Bios, or if you could point me out some tutorials.
                                    Thank you again
                                    • hardware1
                                      • Sep 2021
                                      • 2949
                                      • N/A
                                      Thank you again
                                      Good to know, You're welcome.
                                      After getting the file as you did in Post #16. This file isn't a Full BIOS Image (It's just a BIOS Region), so I replaced it with the old one (You can use UEFITool or HxD) then I cleaned the ME Region.
                                      • Kambi13
                                        • Aug 2022
                                        • 134
                                        • Portugal
                                        Yea I know it's not the full bios, just dont know what and where to replace it
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
