Surface Pro 6 password
  • logix7676
    • Jul 2025
    • Albania
    #101
    Originally posted by hoaca388
    Unlocked
    i tried to flash the image but i get Error 368: Failed to disable write protection for the BIOS space. FPT Operation Failed
    • Fabelo
      • Aug 2025
      • France
      #102
      Hello, I'm new to this forum.
      I don't quite understand what to do!
      I don't know if you can help me?
      I have a Surface Pro 6, and the UEFI is locked with a password, which the seller didn't give me. (My battery is limited and won't charge more than 50%)
      Can you help me unlock it?
      S/N: 024487390153
      Thank you very much.
      • danito
        • Jun 2016
        • 1151
        #103
        S/N: 024487390153
        post backup bios
        • Fabelo
          • Aug 2025
          • France
          #104
          Originally posted by danito
          post backup bios
          Sorry, I've searched everywhere, but I haven't found how to backup the BIOS.
          Can you tell me how?
          Thank you very much, and sorry.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12420
            #105
            "Backup bios" is the content of the bios chip in your computer, it is a password-protected version, to get it you must use a hardware device called a programmer. There are many programmer brands but the cheapest (cheapest does not mean the best) is CH341A.
            https://www.badcaps.net/forum/troubl...21#post1622421
            https://www.youtube.com/results?sear...41a+flash+bios
            • Datofalso
              • Sep 2025
              • 7
              • Italia
              #106
              Hi, I have a Surface Pro 6 1796 with a password locked Bios. I have dumped the original BIOS, but I can't find a clean bios in order to swap the Bios Region. Can you help me Cleaning the Bios password in my dump? BIOS CHIP: W25Q128JVPQ
              S/N: 054415285253
              • hoaca388
                Badcaps
                • Jan 2022
                • 12420
                #107
                Originally posted by Datofalso
                Xin chào, tôi có một chiếc Surface Pro 6 1796 với BIOS bị khóa bằng mật khẩu. Tôi đã dump BIOS gốc, nhưng không tìm thấy BIOS sạch để hoán đổi Vùng BIOS. Bạn có thể giúp tôi xóa mật khẩu BIOS trong dump của tôi không? CHIP BIOS: W25Q128JVPQ
                S/N: 054415285253
                Unlocked
                • Datofalso
                  • Sep 2025
                  • 7
                  • Italia
                  #108
                  Unlocked
                  It pops out Windows logo and then it turns off.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12420
                    #109
                    Try
                    • Datofalso
                      • Sep 2025
                      • 7
                      • Italia
                      #110
                      Try
                      Hi, thank you, but it is still the same, it appears for a few seconds the boot logo and then it turns off. What can I do?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12420
                        #111
                        Chech hardware.
                        • Datofalso
                          • Sep 2025
                          • 7
                          • Italia
                          #112
                          Chech hardware.
                          Thank you, it turned on, but touch is not working. Cable and screen tested on an other surface, and they work on it.
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12420
                            #113
                            See more :
                            https://www.badcaps.net/forum/troubl...e-fix?t=104153
                            • Datofalso
                              • Sep 2025
                              • 7
                              • Italia
                              #114
                              Thank you so much, and sorry if I'm still bothering you. I read the post you linked, but I still haven’t figured out how to fix the issue. I don’t have a clean ME region—should I use my original dump and replace its ME region with the one you cleaned?
                              Also, I noticed that in my original dump, Integrated Sensor Hub Supported is set to NO, while in the cleaned dump you sent me, it’s set to YES. Is that the part I should correct?
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12420
                                #115
                                Here,
Name:	2025-10-02 21_52_19-Settings.png
                                • Buzzfuzz2k
                                  Bios password removal on a Unowhy dump
                                  by Buzzfuzz2k
                                  Hi Everyone,
                                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                  the Computer is a Unowhy small pc
                                  N° UYM6524702229
                                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                  My first attempt was to get the bios dump from windows...
                                  11-13-2023, 07:37 AM
                                • dell_bios
                                  Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                  by dell_bios
                                  I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                  The board has three SPI flash chips:
                                  - W25Q64FV (main BIOS)
                                  - W25Q32FV (EC/TPM)
                                  - W25X10CL (configuration)
                                  I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                  The dump contains protection that needs to be removed.
                                  If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                  I’m also happy to share my dump for comparison if needed.
                                  Laptop model: [please specify, e.g....
                                  10-16-2025, 04:28 PM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • traxformania
                                  TONGFANG "GM7TG7P" Bios Password Problem?
                                  by traxformania
                                  I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                  But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                  I'm trying to reset my bios without success.
                                  I tried :
                                  -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                  11-15-2023, 07:32 AM
                                • ArkzG
                                  [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                  by ArkzG
                                  Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                  What I currently have available:
                                  - Model: FA506NF (2021)
                                  - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                  - Tools: CH341A programmer ready to use
                                  Does anyone have either a clean 2MB .bin dump of this model,...
                                  09-26-2025, 09:34 PM
