Lenovo T490s bios password request.
  • piszpunta
    • Jan 2019
    • 249
    • poland
    #41
    Re: Lenovo T490s bios password request.
    lenovo T490s
    motherboard FT491/FX390 NM-B891 REV 2.0
    sn:PC-1CV0B4
    Not Booting Up Only Fan Running, No Display
    please help
    • volinakis
      • Jan 2021
      • 2798
      • N/A
      #42
      Originally posted by piszpunta
      lenovo T490s
      sn:PC-1CV0B4
      please help
      try clean ME bios.
      • piszpunta
        • Jan 2019
        • 249
        • poland
        #43
        Originally posted by volinakis
        try clean ME bios.
        Unfortunately it does not work
        • volinakis
          • Jan 2021
          • 2798
          • N/A
          #44
          try this, bios region replaced with last update.
          • piszpunta
            • Jan 2019
            • 249
            • poland
            #45
            doesn't work
            • volinakis
              • Jan 2021
              • 2798
              • N/A
              #46
              doesn't work
              maybe is EC - i think is MEC1663 - try to write it.
              • piszpunta
                • Jan 2019
                • 249
                • poland
                #47
                I need working mec dump
                • Rashid334
                  • Apr 2023
                  • UAE
                  #48
                  HELLO EVERY ONE CAN HELP ME REMOVE SUPERVISOR PASSWOR
                • krogs214
                  • Sep 2017
                  • 83
                  • Philippines
                  #49
                  Hi anyone can help i have Absolute Enable but No Bios Password
                  anyone can disable it?
                  Lenovo T490s
                  Sn: PC1F1WZK
                  Board Number: FT491 FX390 NM B891 FEV 2.0
                  thanks in advance
                  • volinakis
                    • Jan 2021
                    • 2798
                    • N/A
                    #50
                    Lenovo T490s
                    Sn: PC1F1WZK
                    thanks in advance
                    try
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12090
                      #51
                      Lenovo T490s
                      Sn: PC1F1WZK
                      thanks in advance
                      Try
                      ​https://www.badcaps.net/donate
                      • krogs214
                        • Sep 2017
                        • 83
                        • Philippines
                        #52
                        try
                        hi its working
                        thank you so much
                        • krogs214
                          • Sep 2017
                          • 83
                          • Philippines
                          #53
                          Originally posted by hoaca388
                          Try
                          thank you also
                          • OntarioTL
                            • Feb 2022
                            • 55
                            I was experimenting on a T490s that has no password but absolute activated. I want to disable it of course. I thought it would be in the MEC1663 but I was wrong as I know with password reset with the MEC trick works to gets rid of Absolute or Computrace on other models. Secondly examining the last request original BIOS and fix applied by volinakis and hoaca388. I decided to compare my BIOS image and make the two adjustments I see in the fix with no luck. Am I missing something here? Or is the value different per activation and deactivation?
                            My untouched BIOS image before I made changes.
                            Lenovo T490s
                            Sn: MJ-0CJQ2R
                            TN: 20NY-S3L500
                            • volinakis
                              • Jan 2021
                              • 2798
                              • N/A
                              #55
                              Lenovo T490s
                              Sn: MJ-0CJQ2R
                              TN: 20NY-S3L500
                              try
                              • OntarioTL
                                • Feb 2022
                                • 55
                                try
                                Unfortunately it did not work. I do see what I did on my attempt that screwed me up however. I noticed the difference between yours and hoaca that there were 2 changes where yours was only one. Would that be the issue?
                                • volinakis
                                  • Jan 2021
                                  • 2798
                                  • N/A
                                  #57
                                  there are too many AbtState invalidated. It should have worked since AbtState is invalidated, i did tens of lenovos in that way. Did you enter in bios setup to Security-Absolute and disable it? Remove CMOS battery if you forget to do it and press power button for 30s, start laptop without battery.
                                  • OntarioTL
                                    • Feb 2022
                                    • 55
                                    I take it back. It worked. For some reason this morning I managed to have it boot without the Absolute activated before I was about to try your suggestions. Strange, but happy nontheless. Thanks for the help!
                                    Now to make my day brighter, I hope to get this E15 working after a botched BIOS update.
                                    • OntarioTL
                                      • Feb 2022
                                      • 55
                                      Ok, so I attempted to modify another BIOS with the same AbtState enabled. I thought it would be easy to modify though UEFItools but of course the option is greyed out. The older UEFItools I've used can extract but it's not as simple as the HEX view from the newer version as it isolates that particular item. I've looked at other posts about how to change this option AA553F to AA553C , but I have noticed from Hexviewer that this option is not always located near the AbtState or it may not be for AbtState at all. My head hurts between this and a E15 Bios issue.
                                      I hate asking for help, but I would greatly appreciate a fix for one more laptop. I want to learn, and I spent a good 3 hours last night at home in front of the screen to find how to go about this. Every time it seems easy on a post, my results are different. I know it will be a slap in the forehead once it clicks on how to do and it's probably pretty easy, but for now I wave the white flag.
                                      Lenovo T490s
                                      TN: 20NY-S3L500
                                      SN: MJ-0CJQ2L
                                      Board : FT491/FX390 NM-B891
                                      • volinakis
                                        • Jan 2021
                                        • 2798
                                        • N/A
                                        #60
                                        Lenovo T490s
                                        TN: 20NY-S3L500
                                        SN: MJ-0CJQ2L
                                        AA553F -enabled
                                        AA553C -disabled
                                        remove CMOS battery, that's why you weren't able to disable Absolute from bios setup. At 1st boot enter bios setup Security-Absolute (somemtime Computrace) and permanently disable it.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • RMDUiFT
                                          Should I buy a Lenovo Thinkpad E495 with bios password?
                                          by RMDUiFT
                                          Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                          I have a few questions:
                                          • If I would buy this laptop and have
                                          08-25-2024, 09:00 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • baaligoga
                                          Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                          by baaligoga
                                          Good day, everyone!
                                          I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                          I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                          05-20-2023, 09:48 AM
